Barglowski Posted September 14, 2005 Share Posted September 14, 2005 Hi all! I have some questions about HID dual hi/lo H4 bulbs, when used on the R1100RT. I'd like to have the dual setup, with the mechanical movement to align the bulb for the high setting and not a second halogen bulb. Is there any problems with using the mechanics? As, will they hold up to the vibration? Also, I've seen some units that have a shield/reflector that seems to hold the topside of the bulb, but appear to block about half of the light. I'd think you'd want to the light to go out all around the bulb and not be blocked, but does that really matter? Any insight will be helpful! Later, jan Link to comment
