RichR Posted September 13, 2005 Share Posted September 13, 2005 First post, been reading for a while. I've searched for this but no luck. Just rode home on a 2004 R1150RT. First BMW and I'm duly impressed. Is there a way to have the turn indicators on, as running lights, and also function as turn indicators? I've read where having these on (like on a Goldwing) MAY cause a few more drivers to see the bike. Thanks. If this has been covered somewhere already, I apologize for my lousy searching. Link to comment
Les is more Posted September 13, 2005 Share Posted September 13, 2005 Welcome! Here's a LINK to info about the Kisan Signal Minder which can turn your signals into running lights along with making them self canceling. Check here for a good tutorial on the use of the search function. Link to comment
Are12C Posted September 13, 2005 Share Posted September 13, 2005 I use a Signalminder from Kisan Technologies for my R1150RT. I don't know if Kisan makes one for the new R1200RT but I'm sure one can't be too far down the road. The signalminder even allows you to alter the voltage on the fly for brighter or dimmer lights. You can even turn the lights off while in motion (say in the event an LEO comes along). (Amber lenses on the rear of a vehicle are not legal in all states if any.) Link to comment
BobFV1 Posted September 13, 2005 Share Posted September 13, 2005 I second the Kisan Signalminder recommendation - it is an easy install, there is great customer service from the factory, and not only can you do running lights in two different intensities, it also gives you self-cancelling turn signals, which for some unfathomable reason the BMW factory does not! Try www.cyclegadgets.com to find the Signalminder. Link to comment
RockLives Posted September 13, 2005 Share Posted September 13, 2005 Kisan makes it. You have the ability to adjust the brightness of the solid turn signal light, and 3 adjsutments for the time outs, either 8 sec., 30 sec., or 45 sec.In addition if you hold the turn signal for 2 secs., it will flash very fast for 5 secs., that really alerts the person in front or behind. Link to comment
RichR Posted September 13, 2005 Author Share Posted September 13, 2005 Thanks. I had the Kisan Signal minder on my list of goodies, but didn't realize that it would work as I wished. I'll slap myself silly for not searching/reading better. Link to comment
Hoover Posted September 16, 2005 Share Posted September 16, 2005 Check out www.run-n-lites.com Allows you to replace your bulb with the stock 1157 bulbs found at just about any auto parts store too. That is always good if you lose bulb on a trip. Link to comment
RFW Posted September 16, 2005 Share Posted September 16, 2005 Is there a way to have the turn indicators on, as running lights, and also function as turn indicators? Sure. A former owner did it with my K100, and it is worthwhile. All you need to do is replace the single filament turn signal bulbs with standard dual filament ones (usually #1187 types, I think), and wire the smaller filaments to the headlight system. The heavier filaments are connected to your signals. This will require new sockets, but these are available at auto suppliers in different sizes, one of which ought to fit. Bob. Link to comment
