Paul Szilard - Australia Posted September 16, 2009 Share Posted September 16, 2009 I would like to hear from anyone that has actual experience of fitting and using a Power Commander on a 12RT (or any R1200). I've had Power Commander on my Japanese bike and the biggest benefit had been low rev flexibility. My questions are; 1) Is the R1200 CANBUS motor suitable for Power Commander? 2) Is the result noticeable? 3) Is fitting a PC a big job? (I've been told it takes 6 hrs!) Thnx Link to comment
smiller Posted September 16, 2009 Share Posted September 16, 2009 Sorry, no personal experience with a 1200 here (although I do have a Power Commander installed on my 1100), but I will offer the following comment... installing a Power Commander on a hexhead would involved disabling the O2 sensors and going open-loop only. I'm not really sure that there would be any benefit to this (absent significant engine modifications) as the hexheads are set up pretty well in stock condition. While the oilheads (1100/1150) can show slight improvements by fattening up the fueling I doubt you'd see any significant increase in ether power or driveability on a stock hexhead. Is there a specific problem you're trying to address? Link to comment
Mister Tee Posted September 16, 2009 Share Posted September 16, 2009 A wide band Power Commander does preserve the closed 02 sensor feedback loop, using a replacement oxygen sensor that has a greater resolution than most stock sensors. And with either PC, it's still possible to map for an economy cruise. I don't know if the wide band PC is available for BMW's though. Link to comment
T__ Posted September 16, 2009 Share Posted September 16, 2009 M.T. the 1200 hexhead uses (2) 02 sensors.. As far as I know Power Commander only offers an open loop version for the 1200 hexhead.. Twisty Link to comment
smiller Posted September 16, 2009 Share Posted September 16, 2009 I don't know if the wide band PC is available for BMW's though. The wideband model (with O2 sensor and full closed-loop fueling control) is available for the 1100/1150 but not the 1200. Link to comment
Paul Szilard - Australia Posted September 18, 2009 Author Share Posted September 18, 2009 Sorry, no personal experience with a 1200 here (although I do have a Power Commander installed on my 1100), but I will offer the following comment... installing a Power Commander on a hexhead would involved disabling the O2 sensors and going open-loop only. I'm not really sure that there would be any benefit to this (absent significant engine modifications) as the hexheads are set up pretty well in stock condition. While the oilheads (1100/1150) can show slight improvements by fattening up the fueling I doubt you'd see any significant increase in ether power or driveability on a stock hexhead. Is there a specific problem you're trying to address? I would like a bit more pull at low revs. I don't like revving the stuffing out of my bikes, but I love tracktability. e.g what the K1300GT delivers, or the Hyabusa/B-King, or GSX1400. But no, I am NOT going back to Japanese bikes . This is my 4th BMwobbleU and I love it to bits. Just would like a bit more low end grunt. But, I am getting used to adjusting my expectations... Link to comment
motoguy128 Posted September 18, 2009 Share Posted September 18, 2009 Sorry, no personal experience with a 1200 here (although I do have a Power Commander installed on my 1100), but I will offer the following comment... installing a Power Commander on a hexhead would involved disabling the O2 sensors and going open-loop only. I'm not really sure that there would be any benefit to this (absent significant engine modifications) as the hexheads are set up pretty well in stock condition. While the oilheads (1100/1150) can show slight improvements by fattening up the fueling I doubt you'd see any significant increase in ether power or driveability on a stock hexhead. Is there a specific problem you're trying to address? I would like a bit more pull at low revs. I don't like revving the stuffing out of my bikes, but I love tracktability. e.g what the K1300GT delivers, or the Hyabusa/B-King, or GSX1400. But no, I am NOT going back to Japanese bikes . This is my 4th BMwobbleU and I love it to bits. Just would like a bit more low end grunt. But, I am getting used to adjusting my expectations... Most aftermarket exhaust won't give you much imrpovement in the bottom end. In most cases, they create flat spots or reduce pwoer off the bottom. It may feel faster because it's a little louder, but a dymno will often say otherwise. To improve the bottom end, you're best bet to to use shorter final drive gearing. Link to comment
