Lineareagle Posted September 15, 2009 Share Posted September 15, 2009 I an unable to start the bike '06 GSA with the bike in gear, side stand up and the clutch disengaged. There appears to be a sensor at the clutch lever. Has anyone had this issue before? How do I trouble shoot it? Starts in neutral. Dies when you drop the side stand. So I'm thinking it isn't sensing the clutch disengaged. Link to comment
RodB Posted September 15, 2009 Share Posted September 15, 2009 My '05 RT does the same occasionnally; after I engage the clutch and disengage again, it's OK. Link to comment
Lineareagle Posted September 15, 2009 Author Share Posted September 15, 2009 My '05 RT does the same occasionnally; after I engage the clutch and disengage again, it's OK. Ya, that worked for awhile, now nada. Want to make sure I am not missing something that will leave me stranded sometime. Link to comment
jaytee Posted September 15, 2009 Share Posted September 15, 2009 This is a fairly common part to go bad. Most BMW dealerships stock the part for around $25 and can change it while you wait for 1/2hr charged labor if you dont feel like doing it yourself. It's definately the clutch switch. JT Link to comment
Lineareagle Posted September 15, 2009 Author Share Posted September 15, 2009 This is a fairly common part to go bad. Most BMW dealerships stock the part for around $25 and can change it while you wait for 1/2hr charged labor if you dont feel like doing it yourself. It's definately the clutch switch. JT TNX maybe the dealers in the US do but here they want $45.00 and 14 days to import it! I did find it on Max fiche so maybe I'll get one on a trip someday. Link to comment
Turf man Posted September 15, 2009 Share Posted September 15, 2009 MAX is the man for us up north. Do not forget Street Cycle in Freeport, Maine, I think, good people. Link to comment
Ken H. Posted September 15, 2009 Share Posted September 15, 2009 The clutch switch has a limited amount of adjustment by bending the tab in it. Listen closely for the ‘click’ when you cycle the lever. If it is very near the start or the end of the pull (or not at all) it may be as simple as adjusting the switch. Save’s you the $$ if so. Link to comment
