Allen Rowand Posted September 15, 2009 Share Posted September 15, 2009 I put the Aerostich headlight protector on a while back- the one that has adhesive that goes directly on the lens. Today I installed an Eastern Beaver headlight relay kit (still using a stock bulb) and am wondering if the higher output will cause the lamp to overheat with the film on the lens. What a difference in output! I know it's not HID, but my headlight looks like a proper light instead of a little candle behind a lens. Thanks for the idea, Selden! Allen Link to comment
Mr_Ed Posted September 15, 2009 Share Posted September 15, 2009 I wouldn't worry about it. Due to the extra heat the bulb may fail a bit sooner but for the extra visibility you achieve it sounds like it would be a reasonable trade-off. Link to comment
Selden Posted September 15, 2009 Share Posted September 15, 2009 At the other end, I replaced my brake light bulb with a Candlepower 55 watt halogen. Big mistake: both the socket and the part of the tail light assembly it plugs into are melted. If I can buy a socket alone, I think I can futz with the tail light assembly enough to get it to fit and stay in place. Anybody have a surplus R1100/1150RT tail light assembly they want to unload cheap? Link to comment
DavidEBSmith Posted September 15, 2009 Share Posted September 15, 2009 I don't think the incremental increase in output using the same headlight bulb with relays will cause any problems. It's only a few tenths of a volt you gain, it would be on the order of a 10% increase in power at worst. If you were switching from a 55W to a 100W bulb, then you start to be concerned. But with the headlight relay, you're upping the power from 55W to maybe 60W - not enough extra heat to worry about. Bulb output is non-linear, that's why you get a huge increase in light output from a small increase in voltage. Quoting from Daniel Stern's lighting site : The drop in light output is not linear, it is exponential with the power 3.4. For example, let's consider a 9006 low beam bulb rated 1000 lumens at 12.8 Volts and plug in different voltages: 10.5V : 510 lumens 11.0V : 597 lumens 11.5V : 695 lumens 12.0V : 803 lumens 12.5V : 923 lumens 12.8V : 1000 lumens ←Rated output voltage 13.0V : 1054 lumens 13.5V : 1198 lumens 14.0V : 1356 lumens ←Rated life voltage 14.5V : 1528 lumens Link to comment
David R Posted September 15, 2009 Share Posted September 15, 2009 SO, now you have me curious. I am going to put a volt meter between batt + and the + on the bulb to see how much voltage I am losing. I'll do the same for ground. I doubt its more than a couple of tenths. Link to comment
