realshelby Posted September 14, 2009 Share Posted September 14, 2009 On my '04 RT I have had the stock seat, modified stock seat, and every seat cushion/butt massager known. I then bought a used Corbin and while better it was too hard for me. I tried a friends Corbin for a few rides just to make sure and they were about the same. I do have a tailbone injury that makes that area the limit to my comfort. I sent off the stock seat to Cee Bailey. Big improvement although I think the shape could have been better. It is actually excellent for rides up to about 2 hours. Next I bought a used Russell Day long. I put MANY thousands of miles on it. Unfortunately it was covered in grey leather and looked like...So I thought I would send it in and have it custom made for me! When I got it back It was noticeably more firm than before. Thought that maybe it needed a break in. I learned later that they are using different foam than they were before. I took the seat cover off and done a little reshaping which helped. It was never as good as the original.I recently bought a seat pan from a member here to modify. I wanted something much longer from front to back with an angle more like a car seat ( rear lower than front). I cut the back off the seat pan, added steel plates to the side to support the foam and support the area in the rear of the pan. I bought High Density foam and went to work. I built it and then took rides on it to see what it needed. I went with cloth because it is softer. This is not for everyone, looks were not my priority and it is too tall for most also. But I can ride in comfort again! Link to comment
elkroeger Posted September 16, 2009 Share Posted September 16, 2009 Hey, if it works, it works. That's a pretty good lookin' home upholstery job. I hate to say it, but you could've saved yourself all that time and money by going to Rich's in the first place. http://www.richscustomseats.com/ Link to comment
Firefight911 Posted September 16, 2009 Share Posted September 16, 2009 There's a really good article in MCN this month all about DIY seats. Worthwhile read for those so inclined to tackle their own seat farklization. Link to comment
realshelby Posted September 16, 2009 Author Share Posted September 16, 2009 Hey, if it works, it works. That's a pretty good lookin' home upholstery job. I hate to say it, but you could've saved yourself all that time and money by going to Rich's in the first place. http://www.richscustomseats.com/ If I can do it I am sure Rich's could have...but it would have had to be a ride-in job. And there is no way I could have saved money, the time to engineer what I done to the base plate, fabricate the steel reinforcements and attach them would have run the cost of the seat into the thousand (s?). Not to mention that I made 3 major redo's to the foam before adding the cover. Most aftermarket seat makers would have refused the job. Not wanting to cut up a base plate or re-engineer it. Link to comment
elkroeger Posted September 17, 2009 Share Posted September 17, 2009 Actually I was kinda thinking stop at Rich's before you bought the Russell, Cee Bailey and the Corbin. He does mail-in work too. Link to comment
