Starfighter Posted September 10, 2009 Share Posted September 10, 2009 I have a BMW advanced charger and periodically put it on the bikes. Question is : Can I leave it on one of the bikes for months like a battery tender ? (both bikes are non-Canbus) Link to comment
Firefight911 Posted September 10, 2009 Share Posted September 10, 2009 Deltran makes the BMW chargers and they are smart charger programmed so they will go to float mode just as a Battery Tender does. Link to comment
Starfighter Posted September 10, 2009 Author Share Posted September 10, 2009 Thanx Phil I am a happy guy.............. Link to comment
Quinn Posted September 11, 2009 Share Posted September 11, 2009 If you don't have a sealed battery, it wouldn't hurt to check the fluid level in case it's been overcharging and boiling off liquid. Link to comment
Lmar Posted September 11, 2009 Share Posted September 11, 2009 I have a battery tender jr which I used on my K1200RS and my Goldwing. Can I hook it to my battery and use it on my 09 RT? Link to comment
Firefight911 Posted September 11, 2009 Share Posted September 11, 2009 I have a battery tender jr which I used on my K1200RS and my Goldwing. Can I hook it to my battery and use it on my 09 RT? Absolutely no issue whatsoever! Plug in, walk away, enjoy. LINKY Just remember to either bypass your stock accessory socket so it is direct to battery to bypass the controlled portion of the circuit or go direct to battery with it. Link to comment
Skywagon Posted September 12, 2009 Share Posted September 12, 2009 slight hijack...I put my Deltrans Battery Tender Plus on a deep cycle boat battery recently. I let it sit over night. The red light never went off and the charger was hot as H E double hockey sticks. I unplugged it, put it on my bike and it functions fine. I used a much heavier (20 amp) charger on the boat battery and all is well So the question...are these chargers too light duty to charge something that heavy? I realize 1.2 volts out would take a long time to charge 105 Amp battery, but was curious if it could be used as a maintainer without burning up the charger. Thanks. Link to comment
too old to care Posted September 12, 2009 Share Posted September 12, 2009 I have one on my battery back up sump pump and it works fine. Keeps two group 27 batteries (70ah)topped off just fine. But to charge a battery that size takes days. Think of this way, two 70 ah batteries (140 ah) divided by 1-1/2 amps would take, duh, a long time. Link to comment
