steve2 Posted September 8, 2009 Share Posted September 8, 2009 Read the ways and means to replace the belt. It was a fairly easy job once I remembered what the procedure was. My question is this- I found very small pieces-flakes of metal in the belt tracks on the belt I removed. Where would these flakes be coming from and has anyone else seen this? Link to comment
Ken H. Posted September 8, 2009 Share Posted September 8, 2009 Plating from the pulley? Link to comment
Albert Posted September 8, 2009 Share Posted September 8, 2009 I would agree with Ken, this is likely from the pulley itself. This is really not an uncommon condition. Harley Davidson has used final drive belts for years (very successfully I might add). There is actually a service interval for both inspecting and replacing the drive pulleys on these systems. Link to comment
steve2 Posted September 9, 2009 Author Share Posted September 9, 2009 plating from the pully? Is it hard on a belt? Does this mean the pully is going bad? Does everyone have theis trouble. ? Should I be worried? Link to comment
Ken H. Posted September 10, 2009 Share Posted September 10, 2009 plating from the pully? Is it hard on a belt? Does this mean the pully is going bad? Does everyone have theis trouble. ? Should I be worried? Naw, I've not yet seen or heard of an issue because of it. We're talking very fine material migraton. Link to comment
Albert Posted September 10, 2009 Share Posted September 10, 2009 plating from the pully? Is it hard on a belt? Does this mean the pully is going bad? Does everyone have theis trouble. ? Should I be worried? If it helps keep your mind off of the final drive exploding then yes, worry. Sorry, just kidding, what Ken said. No big deal. Link to comment
