Whip Posted September 7, 2009 Share Posted September 7, 2009 Anyway to losen the tension of the throttle spring??? Link to comment
T__ Posted September 7, 2009 Share Posted September 7, 2009 Whip, sure there is always a way.. Now if you had asked if there is an easy way then NO.. You have a stout wound spring on both TBI units so there is a fair amount of tension due to two springs.. Probably the easiest way is to rig up a counter spring (or rubber band) right on the twist grip to twist the grip back against the TBI spring pressure.. Not pretty but seems to work pretty good.. Twisty Link to comment
Boone60 Posted September 7, 2009 Share Posted September 7, 2009 I use the Throttlemeister throttle holder and add just some drag to take up a bit or the rewind tension. Link to comment
Whip Posted September 7, 2009 Author Share Posted September 7, 2009 Whip, sure there is always a way.. Now if you had asked if there is an easy way then NO.. You have a stout wound spring on both TBI units so there is a fair amount of tension due to two springs.. Probably the easiest way is to rig up a counter spring (or rubber band) right on the twist grip to twist the grip back against the TBI spring pressure.. Not pretty but seems to work pretty good.. Twisty What about a counter spring at the TBs??? Link to comment
T__ Posted September 7, 2009 Share Posted September 7, 2009 Whip, possibly.. Problem with a counter spring on the actual TBI units is the failure mode.. If you have a counter spring on the TBI & the main return spring fails the TBI goes to spring held wide open.. Same with a broken cable (maybe not enough return spring to return the throttle plate to idle).. On the other hand if you have a counter spring on the twist grip any cable failure allows quick return to idle,, or you just manly twist the grip back to idle.. Twisty Link to comment
philbytx Posted September 7, 2009 Share Posted September 7, 2009 Suffering from a weak right wrist Whipster Well, don't worry, I'm not going there....although I really COULD LOL Link to comment
Lawman Posted September 7, 2009 Share Posted September 7, 2009 Whip, possibly.. . If you have a counter spring on the TBI & the main return spring fails the TBI goes to spring held wide open.. Twisty Can I watch? Link to comment
ESokoloff Posted September 8, 2009 Share Posted September 8, 2009 Larry, I have a Throttle Rocker that I put on my 03 RT right after my first 50+ mile slab ride. I found that my wrist can not take holding sustained constant throttle. That was about 70k ago. The attachment designed was changed due to copywrite infringements & I have the original & have not tried the current offering. Note that some swear by these & some swear at them but at less then $15 it's painless enough to see if it works for you. Link to comment
11101110 Posted September 8, 2009 Share Posted September 8, 2009 I got one of these: http://www.mccruise.com/BMW-R-Series-Electronic-Cruise-Controls.html Link to comment
philbytx Posted September 8, 2009 Share Posted September 8, 2009 Ok Whip! Enough of the jesting......... To ease your pain......THROTTLEMEISTER I installed the larger end weight...it will reduce the vibes too . Link to comment
Whip Posted September 8, 2009 Author Share Posted September 8, 2009 I have a Kaoko Throttle Lock thingy, I've used a wrist rest. They ain't what I was looking for. ...but thanks. L Link to comment
10ovr Posted September 8, 2009 Share Posted September 8, 2009 Is-ant it about time for a new bike yet,,Hell you have had this one for a long time,, Link to comment
flars Posted September 8, 2009 Share Posted September 8, 2009 "Anyway to losen the tension of the throttle spring???" Beth says you're a Sissy. I say the throttle tube may need a little grease - you may be fighting that rather than the spring tension. Link to comment
Bill_Walker Posted September 12, 2009 Share Posted September 12, 2009 I say the throttle tube may need a little grease - you may be fighting that rather than the spring tension. Another possibility is gunk in the Bowden box causing drag (Whip, that's the box that takes the single cable from the twistgrip and splits it into two cables that go to the two throttle bodies. It's conveniently located under, well, pretty much everything). Link to comment
