JCBMW Posted September 11, 2005 Share Posted September 11, 2005 Hi all I just installed the BMW clarion radio on my RT. Plugged everything in, turned the key, pushed the power button, and, nothing. Rechecked all the connections and tried again. Still nothing. Any ideas as to why? Link to comment
David Posted September 11, 2005 Share Posted September 11, 2005 Any chance you are trying to play a Barry Manilow song? Link to comment
MattS Posted September 11, 2005 Share Posted September 11, 2005 Any ideas as to why? Security code? Link to comment
RockLives Posted September 11, 2005 Share Posted September 11, 2005 Check the antenna, you will find they need to be connected, now if you do not have power, then be aware that there is a secondary in line fuse, not the one in the fuse bax. Link to comment
JCBMW Posted September 11, 2005 Author Share Posted September 11, 2005 OK...I see that there is a # 10 fuse in the back of the radio itself. Where would the one in the fuse box be positioned. Looking from the center out the # 2 position is empty. Could this be the one and if so is it also #10? Link to comment
RockLives Posted September 11, 2005 Share Posted September 11, 2005 I believe it is 10, however throw one in each. I am not sure of the amps, probably the same as the in line fuse. Link to comment
HoMa506 Posted September 12, 2005 Share Posted September 12, 2005 Hi Jay, I see in your profile you have an '02 also so it shouldn't be anything different from mine. When I put it in it was truly a straight forward plug and play no codes or fuses to add. You should of had all speaker, antenna and ground wires installed as stock. When you say you pushed the power button and nothing do you mean nothing, nothing? or nothing as in sound? Usually a nothing as in nada is a ground or power problem. I followed the instructions as described in the web site I referred you to, as you can tell from the plug connectors it's impossible to get wrong so I can't even think of why it's not working. I hope you still have all the plastic off. I know you said you checked all the connectors but maybe a 3rd time and go step by step. Did you include checking the connector on the back of the radio in the box? Please keep me informed I really feel bad it's not working. Link to comment
Haynes Posted September 12, 2005 Share Posted September 12, 2005 It sounds as if you have no power at all. Even when you finally get power, you'll need to tune each station before you hear anything. Link to comment
JCBMW Posted September 12, 2005 Author Share Posted September 12, 2005 OK...All connections are hooked up securely. I am missing the antenna wire which runs from antenna to the radio. My thinking was that even without the antenna wire attached that the display would still light up in order for me to see that there was power going to the radio. I have one empty fuse slot in the on bike fuse box. It is the second one from the inside out. Is this one for the radio as well? I'm kinda bummed that it didnt come on when I pushed the button. My poor bike is in peices out in the driveway. Jay Link to comment
JCBMW Posted September 12, 2005 Author Share Posted September 12, 2005 OK...got it working. Had to tear apart the housing on the radio due to the on off control and audio buttons being lopsided. Once I tightened the screws on the inside I could turn it on. Thanks everyone Link to comment
RockLives Posted September 13, 2005 Share Posted September 13, 2005 Ok now turn up the volume Link to comment
JCBMW Posted September 13, 2005 Author Share Posted September 13, 2005 False hope. It worked for about 2 minutes. Now I cant get the cassete out of it. Im going to the Sony as soon as I find out which model it is. Link to comment
