ACsRT Posted September 11, 2005 Share Posted September 11, 2005 Last month I bought a 2002 R1150RT with 3200 miles on it , I now have 6300 miles. I read up on adjusting the valves and synchronizing the TBs. Questions: 1. Do i have to remove the Tupperware to do the valves? 2. Do I use locktight on the Tupperware or the rocker arm covers? 3. Can I adjust the TBs by only removing the Black RHS Shin Pad and attaching to the LH from underneath? Thanks Andy Link to comment
Bob Palin Posted September 11, 2005 Share Posted September 11, 2005 1. Yes 2. No 3. Never tried it but it looks like it would be very difficult. Actually I don't know how to remove the shin pad, just whip the plastic off and do the valves and TBS at the same time, after a couple of times it becomes easy. Link to comment
Rob L Posted September 11, 2005 Share Posted September 11, 2005 Last month I bought a 2002 R1150RT with 3200 miles on it , I now have 6300 miles. I read up on adjusting the valves and synchronizing the TBs. Questions: 1. Do i have to remove the Tupperware to do the valves? 2. Do I use locktight on the Tupperware or the rocker arm covers? 3. Can I adjust the TBs by only removing the Black RHS Shin Pad and attaching to the LH from underneath? Thanks Andy What Killer said. Never use loctite on the plastic parts or on the valve covers. Buy a manual and use a torque wrench to tighten the valve covers. The bolts strip out the soft aluminum in the heads very easily, I know, I had 3 helicoils on my 98 RT! You need a wrench that reads in inch/pounds. Use the manual to find torque specs., or search on the db for answers. These procedures have all been written up many times before. Doing this job yourself insures that it is done right and gives a great deal of satisfaction (and keeps your wallet in your pocket ) Link to comment
ACsRT Posted September 11, 2005 Author Share Posted September 11, 2005 Killer, Rob Thanks I have a e-copy of a manual and some stuff from ADVRIDER Andy Link to comment
