Melty Posted September 3, 2009 Posted September 3, 2009 It has been a long time since I posted here, many new faces and a lot of the old ones are gone. I had a pinch bolt freeze in the left fork leg, no amount of heat, chemical or swearing would budge it so I pulled the fork leg and will have a machine shop drill it out.While it is off, I might as well change out the fork oil, since it's been in there for a few years and 65,000 miles. How much and what weight should I replace it with? Also time to replace the rear brake rotor, any favorites? The motorbike is a 1999 R1100RT-ABS
Selden Posted September 3, 2009 Posted September 3, 2009 Since the main purpose of the oil in a Telelever suspension is lubrication, not damping, almost anything (within reason) will do. 470 ml (8 oz) of 10-weight fork oil should do the trick. Check the seals while you're in there. I usually add ~20% ATF seal conditioner to the fork oil, whether the seals are leaking or not.
russell_bynum Posted September 3, 2009 Posted September 3, 2009 What Selden said. I just use straight ATF...it really doesn't matter much.
