DMH Posted September 2, 2009 Share Posted September 2, 2009 I got my b-day present ( so it is good getting more birthdays - look at the alternative !)- and the Garmin Zumo 500 arrived - it's not obvious on how to mount it to the 1150RT with the RAM parts supplied - any guidance ? Link to comment
Cycledude Posted September 2, 2009 Share Posted September 2, 2009 You have a few options. Basically you need a way to mount the included parts to the bike. On my RT I have a RAM ball (RAM-B-345)above the clutch master cylinder, then the long 7 inch arm, and on top the Zumo in mount. This places the Zumo just off the left. Other options are out there on how to mount the Zumo using other parts. Its up to you on how you want it. Do you want it off to the left or center? There are many retailers that sell RAM parts. Its really up to you. Snowy. Link to comment
ltljohn Posted September 3, 2009 Share Posted September 3, 2009 I made this mount. The pictures show it before I painted it black. I also ended up using a 2 or 2.5 inch ram arm to get it above the instruments. I have another one that needs to be drilled and painted. The holes for the ram ball are countersunk on the back. If you want it PM me. Link to comment
T__ Posted September 3, 2009 Share Posted September 3, 2009 DMH, it can be mounted with the RAM parts that came with the Zumo but it isn’t pretty & not real easy.. A good way to do the mount on the 1150RT is to buy an additional RAM ball (shown in link below).. Then use a short spacer & longer bolt to install in one of the handle bar mount bolt holes.. It makes an easy to see & use setup that also allows some stealth as your helmet will easily cover the GPS when you stop for a short break.. It also allows a firm mounting that doesn’t shake at speed & keeps the sun from washing the screen out in bright sunlight.. Just click on links below.. http://img.photobucket.com/albums/v18/tractorman22/RAM-9M.jpg http://img.photobucket.com/albums/v18/tractorman22/IMG_2981.jpg http://img.photobucket.com/albums/v18/tractorman22/IMG_2980.jpg Twisty Link to comment
jakfrost Posted September 3, 2009 Share Posted September 3, 2009 There is this option as well... http://gallery.me.com/jkwinchester1#100037&bgcolor=black&view=grid Jim Link to comment
EddyQ Posted September 3, 2009 Share Posted September 3, 2009 THIS zumo forum thread has quite a few options for the 1200RT. Many may work well on the 1150RT also. I personally like the BMW mount, but at $130 . . . Link to comment
David Vale Posted September 4, 2009 Share Posted September 4, 2009 I bought a very neat, simple mount RAM from this guy, based in Stockport (UK). It replaces one of the handlebar mounting bolts. It was for a Zumo 600, but I assume it's the same. http://www.telferizer.com/index.asp Link to comment
dls Posted September 4, 2009 Share Posted September 4, 2009 I highly recommend the mounts made by Jakfrost. They are the best. Link to comment
