creekstone Posted August 31, 2009 Share Posted August 31, 2009 I bought a set of used Ohlins. The rear went on with no problems. The front may have some boogered threads up top; the OEM nut is giving me some resistance. Before I explore my options, can someone confirm that the Ohlins (re)uses the stock OEM nut? TIA Link to comment
Tony_K Posted August 31, 2009 Share Posted August 31, 2009 Don't go any further. Clean up your threads with the proper metric die. Use a new metric nut. I replaced all with metric nyloc nuts for added security. Link to comment
creekstone Posted August 31, 2009 Author Share Posted August 31, 2009 Don't go any further. Clean up your threads with the proper metric die. Use a new metric nut. I replaced all with metric nyloc nuts for added security. I understand that solution if indeed the threads are boogered. I'm looking for confirmation that the same nut fits both the OEM and Ohlins shock. Or in other words... that the threads on both shocks are the same. Anyone? Link to comment
94aero Posted August 31, 2009 Share Posted August 31, 2009 Yes they are the same. Clean the threads and go. But remember to reuse the rubber on top of the shock. Link to comment
Eckhard Grohe Posted September 1, 2009 Share Posted September 1, 2009 Doesn't the nut have a deformed thread locking feature in it. Mine was stiff the first couple of times I removed it but it loosened to the point where I put blue locktite on it to make sure is would stay put. Link to comment
creekstone Posted September 1, 2009 Author Share Posted September 1, 2009 Doesn't the nut have a deformed thread locking feature in it. Mine was stiff the first couple of times I removed it but it loosened to the point where I put blue locktite on it to make sure is would stay put. Hmmm... that's an interesting possiblity. But the nut easily spins on the OEM shock. Everytime I try the nut (by hand) on the Ohlins, it seems to go a tad further. I'm tempted (but know better) to put a wrench to it and gently force it. Neither I or my wrenching bud have the right die. I'll run by my dealer tomorrow to see if they can give me a hand. Thanks to everyone for their comments! Link to comment
