Pilgrim Posted August 24, 2009 Share Posted August 24, 2009 (1) I want to switch displays between two monitors on the same laptop with a shortcut rather than drag and drop. A program called UltraMon shows up from a Google search on the subject. Apparently, it allows pretty extensive manipulation of two monitors. Anybody here have any experience with it? (2) Is there a macro that will save copies of Office documents to multiple files at once and leave you working in the original location? As in save and backup at the same time. Pilgrim Link to comment
Eric S Posted August 24, 2009 Share Posted August 24, 2009 I rock with 3 monitors and use DisplayFusion Pro. Probably similar in functions to Ultramon but Displayfusion has a free version too I think. I bought the Pro because I can have the taskbar on all monitors, plus moving windows is easily done by dragging and dropping via the header bar. www.binaryfortress.com Link to comment
MattS Posted August 25, 2009 Share Posted August 25, 2009 (2) macro will save copies of Office documents to multiple files at once and leave you working in the original location? As in save and backup at the same time If you drop this in the ThisWorkbook module of your workbook, it will save copies to the locations specified in the code: Private Sub Workbook_BeforeSave(ByVal SaveAsUI As Boolean, Cancel As Boolean) ActiveWorkbook.SaveCopyAs "c:\backherup\00.xls" ActiveWorkbook.SaveCopyAs "c:\backemup\99.xls" End Sub This is as plain vanilla as it gets; the folders need to have been created, and won't work on a file that hasn't already been saved once. Link to comment
Fightingpiper Posted August 25, 2009 Share Posted August 25, 2009 I roll with only 2 monitors but have been using UltraMon for a bunch of years now and have been very pleased. Link to comment
