doc47 Posted August 22, 2009 Share Posted August 22, 2009 What's a good method for releasing springs under strong tension. The centerstand on my machine has pretty strong springs. Usually I just clamp on with a pair of Vise-Grips and haul away but there's got to be a better way. Suggestions? Link to comment
T__ Posted August 22, 2009 Share Posted August 22, 2009 Doc, a simple way is to move the stand so the spring is at it’s LONGEST then stack pennies,, nickels,, or washers in between the coils.. When the stand is then put in the up position the spring stays in an extended length & pops off the pins real easy.. You need to stack the coins or washers on both sides of the spring to keep the spring from curling up like a banana but otherwise it works pretty darn good.. Twisty Link to comment
Selden Posted August 22, 2009 Share Posted August 22, 2009 You need to use pfennigs on a BMW spring. Link to comment
Ewell D. Posted August 22, 2009 Share Posted August 22, 2009 I found a spring puller in my toolbox left over from 2-stroke dirtbike days. It was used for removing the expansion chamber and is simply a heavy guage wire with a hook on one end and a loop on the other. It worked well when I removed my center stand springs. Hook the spring where it loops around the stud and pull it off, reverse for installing. Next time I will try the pennies. Link to comment
doc47 Posted August 22, 2009 Author Share Posted August 22, 2009 Pennies. Elegant in its simplicity! Who woulda thunk it? Link to comment
ahirsch Posted August 23, 2009 Share Posted August 23, 2009 I use a spring puller used for drum brakes on a car. You can pick these up at ANY auto parts store for very cheap. Link to comment
