George Brown Posted August 20, 2009 Share Posted August 20, 2009 I'm trying to use the brand new 6-year old spare tire on my Explorer - it's a Michelin with raised white letters. The letters for the most part have yellowed or more accurately turned a tan color with some bright white spots. I have always had the best success using SOS pads to clean white walls but they don't seem to be cutting this tan - at least not as fast as I would like. Any suggestions? TIA Link to comment
10ovr Posted August 20, 2009 Share Posted August 20, 2009 Bon Ami ,,Great stuff for white walls, Link to comment
Nice n Easy Rider Posted August 21, 2009 Share Posted August 21, 2009 George, It sounds like the stain may be a little deeper than just surface. You might try applying a 20% bleach solution and letting it sit awhile before rinsing it off and using the SOS pad and/or cleansers. I've found bleach can do wonders on deep stains. Link to comment
Husker Red Posted August 21, 2009 Share Posted August 21, 2009 I like Westley's Bleche-White. It's worked great for me on regular road grime on raised white lettering. It might discolor concrete because I've noticed the area on the driveway where I apply it it a little different color than the rest of the driveway. That could be from the tire shire or wheel cleaner (most likely) too, but just fair warning. Link to comment
Polo Posted August 21, 2009 Share Posted August 21, 2009 I like Westley's Bleche-White. It's worked great for me on regular road grime on raised white lettering. +1 Haven't used it in a long time, but that stuff worked great on white walls and raised white letters. Also cleaning rubber mats and vynil. Maybe too good on vynil. Link to comment
George Brown Posted August 21, 2009 Author Share Posted August 21, 2009 Did a google search last night for cleaning white walls and got several ideas. One described the same tan color that I had and suggested using 150 grit sandpaper. Tried that this morning for a few moments with success so I fired up my Dremel tool using a sanding drum - grit unknown but coarser than 150 probably about 60. Worked great - had all the letters sparkling white within 3 or 4 minutes. Need a light touch however or one could grind the letters off pretty quickly. Thanks for your suggestions. Link to comment
