JayW Posted August 20, 2009 Share Posted August 20, 2009 Can anyone recommend a company that can rebuild the rear struts on a 1995 Mercedes 500SEL? It has the self-leveling hydraulic suspension. Works, Wilburs, and Ohlins only seem to work on motorcycle shocks. Thanks, Jay Link to comment
ShovelStrokeEd Posted August 20, 2009 Share Posted August 20, 2009 Try HERE Look up the forum for your model and ask. They have some good folks aboard. Link to comment
10ovr Posted August 21, 2009 Share Posted August 21, 2009 If you are getting a hard ride,,It's not the shocks,,Its the hydraulic pods that go bad,,The bladder inside of them leak,,and you get fluid on both sides,,Cant compress fluid,,If you look under the rear follow the line from the shocks to the pod's,,, Link to comment
roadscholar Posted August 21, 2009 Share Posted August 21, 2009 Correct. It's a fairly common problem on the cars with self-leveling rear suspension (wagons and big-engined S class) after they get some miles and years on them. That's why wagons make great tow cars, they self-level at up to 1000 lbs. Link to comment
Highway41 Posted August 21, 2009 Share Posted August 21, 2009 I have not come across any rebuilders for auto shocks but here are a couple of links to good forums where you can inquire: http://www.peachparts.com/shopforum/index.php http://www.mbworld.org/forums/index.php http://www.500espot.com/forums/ I have rebuilt the pump on my '94 but still have the original rear shocks after 166K miles. Good luck. Bill Link to comment
