philbytx Posted August 19, 2009 Share Posted August 19, 2009 Issue: The gearlever sometimes gently "kicks back" against your foot when changing UP from 2nd to 3rd. This is on an R1100R with only 13k on it! So, today I did a 6k powertrain oil change on LeRoy. The engine oil was in good shape, FD was clear as a bell and the gearbox oil was slightly dark/good except for a collection of VERY small steel "grindings" on the magnetic drain plug. No golden sheen, just fine grindings. Given this issue and a little concern on my part, I decided to add some Lucas Transmission Fix to the refill. 1/3 Lucas to 2/3 75w140 synthetic. Rode the bike around the block for a couple of miles and noticed that the 2 to 3 shifting had improved. The next test will be a long ride but I am hoping that this will help. I notice some others on this and other boards have experienced this "kick" with the M97. I previously used the Lucas in my BMW 5speed cager (which uses ATF in the gearbox) when it had a slight seal leak and it worked really well to seal the leak plus I did notice improved shifting. Just passing this on......will update after a few hundred miles. Link to comment
Boone60 Posted August 21, 2009 Share Posted August 21, 2009 Please keep us posted on how this works. Link to comment
Vosper Posted August 21, 2009 Share Posted August 21, 2009 Saw this article on Anton's site . There's a section on "how to shift a BMW." Maybe what you're feeling is the result of the stepped gear dog? Link to comment
philbytx Posted August 22, 2009 Author Share Posted August 22, 2009 Yup! Thanks for the link but I did read this article a while back. And I always pre-load the shifter and my R1150RT with the later tranny shifts beautifully. 1 to 2 and 3 to 4 to 5 are all fine. Its just an occasional kick on the M97....hoping the Lucas TrannyFix will help. Will put a few miles on the box and let folks know the score..... Link to comment
NonComp Posted August 22, 2009 Share Posted August 22, 2009 Recently had my M94 gearbox rebuilt by Bruno. He returned it with a tube of MolySlip Manual Transmission Supplement. I added the recommended amount (1/4 tube per litre). Link to comment
