Aluminum_Butt Posted September 2, 2005 Share Posted September 2, 2005 Due to a mishap, I need to rebuild my side case. I ordered a new back and new rivet sets. The lid, hinges, and gasket are in good shape. Removing and reattaching the lid looks pretty easy. But what about the lock mechanism? There are seven rivets that appear to be holding it inside the case - just drill these out? Any other advice? TIA! Link to comment
bmw_rider Posted September 2, 2005 Share Posted September 2, 2005 You have it under control. Just drill out those rivets as well. Then just rivet it into the new location. Pretty simply actually considering BMW engineered it. Link to comment
Aluminum_Butt Posted September 3, 2005 Author Share Posted September 3, 2005 Well, I got the rivets drilled out and the lock assembly loose. But I can't pull the lock out because there are boots on the "claws" that lock the lid. The boots are too large to go back through the hole, and I can't figure out a way to get them off. What am I missing? Link to comment
bmw_rider Posted September 3, 2005 Share Posted September 3, 2005 Guess I missunderstood what you were doing a little. I just moved the entire locking mechanizm to the new case, re-riveted and moved on. Link to comment
Aluminum_Butt Posted September 3, 2005 Author Share Posted September 3, 2005 That's what I'm trying to do as well. I've attached a picture to help explain. I've got the lock mechanism loose, but I can't pull it out because of the item I've marked with an arrow. If it weren't there, the silver bar that grabs the lid would easily slide out. Link to comment
Michael Fajans Posted September 3, 2005 Share Posted September 3, 2005 The pin that holds the rubber "boot" on the "claw" needs to be knocked out and then pressed back in after installation of the mechanism into the inner case. Link to comment
Aluminum_Butt Posted September 3, 2005 Author Share Posted September 3, 2005 Thanks! I tried to push them out before. But, like so many problems in life, the solution was a hammer. Disassembly all done - now if the UPS guy would just get here... Thanks again for the help. This board rocks! Link to comment
bmw_rider Posted September 4, 2005 Share Posted September 4, 2005 My memory is short, but I don't remember having to do that? Link to comment
