knight88 Posted July 5, 2009 Share Posted July 5, 2009 Anyone remove their sidestand mount plate? I think it involves removing the center stand and wondered how difficult it is and how to prop the bike up with no centerstand. was on a ride and put my stand down, let the bike rest on it and the side stand bracket snapped and bike fell over. its a 02 1150RTP, thanks Link to comment
Haynes Posted July 6, 2009 Share Posted July 6, 2009 The sidestand/centrestand mount is not difficult to remove. The hardest part is removing the return springs. You'll certainly have to take some care in supporting the bike. I have a stand that uses the front axle and supports the forks with the front wheel removed. Link to comment
snod Posted July 7, 2009 Share Posted July 7, 2009 The hardest part is removing the return springs. Start with the stand (side or center) deployed. Then slip pennies and/or dimes in between the coils of the spring. As I recall 10 or twelve is about the right number for those springs. Then retract the stand. The spring is then fairly easy to remove with vise grips. I suppose for those in other countries, there would be some similar sized coin that would work, or you could find flat washers of an appropriate thickness. Link to comment
pmfranke Posted July 7, 2009 Share Posted July 7, 2009 wow, never would have thought of that coin trick. nice job. Link to comment
DonW Posted July 7, 2009 Share Posted July 7, 2009 This actually works much better if you use German pfennigs. BMW sanctioned american pennies are an adequet substitute. I'm sure BMW will sell you 25 of them for $20. Link to comment
ltljohn Posted July 7, 2009 Share Posted July 7, 2009 You will need to use these for the spring. You can get them in sets of 10 for just 12 Euros which is 16.70 USD 19.47 CAD 21.16 AUD 26.57 NZD Link to comment
NoHeat Posted July 8, 2009 Share Posted July 8, 2009 Well, I suppose everybody should have their chance to put in their two cents worth. Link to comment
knight88 Posted July 8, 2009 Author Share Posted July 8, 2009 Okay got the broken bracket replaced I didnt have to remove the center stand to do it, thanks to all for their two cents BTW the dime thing worked great! Link to comment
