Dr Klawn Posted August 26, 2005 Share Posted August 26, 2005 Hi All! I'm finally at the point of upgrading the stock H4 headlight on my R1100RS. In reviewing the options, some bulbs note 6v, 12v and 24v for available H4's. I wasn't aware that they made them for different voltages. Can someone set me straight here? I assume that most, if not all sold in stores are the 12v variety!? I'm planning on using the Osram Silverstars at 55/60w with a relay upgrade to the exsiting wiring. These were tested in the past by a member of this site and seemed a good upgrade. Any issues with non-DOT compliance? Has anyone ever been hassled for have brighter lighting? Thanks! Link to comment
Ken H. Posted August 26, 2005 Share Posted August 26, 2005 All modern BMW bikes are 12v. Link to comment
FrankT Posted August 27, 2005 Share Posted August 27, 2005 Doctor, A relay upgrade is the ticket regardless of the bulb you ultimately choose. As indicated above, your bike is 12V. I added relays to my RT and replaced the stock bulb with a Phillips Vision Plus which made nightime actually enjoyable in which to drive. Don't worry about non-DOT. Link to comment
Dr Klawn Posted August 27, 2005 Author Share Posted August 27, 2005 Hey thanks! I figured it was 12v, I just couldn't remember today while at work. I went ahead and ordered some of the Osram's (European "Silverstar" bulbs). Anything will be better than stock. We'll be leaving in a couple of weeks for a two week ride through the Cali coast and Sierra's and figured I could use a bit more light. Link to comment
steveknapp Posted August 27, 2005 Share Posted August 27, 2005 Osram's (European "Silverstar" bulbs) Good move, there are Silverstar lights in the US and they aren't the same. Short life and not as high of output. FYI, if you've not seen this site you may find it interesting: http://www.danielsternlighting.com/tech/tech.html Link to comment
