Tourbike Posted August 22, 2005 Share Posted August 22, 2005 Under the rear seat, near the accessory plug hole, there's a two conductor female plug. Is this the power for the rear accessory plug that's available as an option? Link to comment
Buccaneer Posted August 23, 2005 Share Posted August 23, 2005 Yes, that's where the accessory plug attaches. Link to comment
JayW Posted August 23, 2005 Share Posted August 23, 2005 Is it as easy at it looks to install the second plug? Jay Link to comment
Buccaneer Posted August 23, 2005 Share Posted August 23, 2005 Haven't done it myself yet, but it certainly does look easy. Assuming you can get hold of one, of course. My dealer has had mine on order for over a month now. Maybe there is a Hella version? Anyone? Link to comment
David_S Posted August 23, 2005 Share Posted August 23, 2005 The ones from powerlet or poweroutlet something like that are a perfect fit. I decided to run the rear to the battery so I don't have to worry about the computer shutting it down. Also makes a nice place to connect a battery tender if you don't have or want the BMW charger. Link to comment
John Bentall Posted August 23, 2005 Share Posted August 23, 2005 I decided to run the rear to the battery so I don't have to worry about the computer shutting it down. Also makes a nice place to connect a battery tender if you don't have or want the BMW charger. I've done the same! Link to comment
Isettanut Posted August 23, 2005 Share Posted August 23, 2005 I installed a rear outlet in mt RT. First remove the rear rack,tail lamp assy and clip the wire tie securing the connector. The right angle plug goes in easy enough but the nut will have to be forced over the connector on the plug sort of thread it on.and assemble in reverse. Cost is $25.00 U.S. Current will remain on for a short time after the ing. is switched off. Link to comment
