Phil50 Posted May 2, 2009 Share Posted May 2, 2009 Hi, Can anyone point me to where I can find the torque specs for the hex studs that hold the foot peg hanger bar on. I took it off to fix the gear shift once and for all and now I can't find what I should torque the studs up to. Many thanks Phil Link to comment
jcguin Posted May 2, 2009 Share Posted May 2, 2009 I'm not sure which bolt you are talking about. But does this answer your question. If not, I'll find something else. Jim Link to comment
Boffin Posted May 2, 2009 Share Posted May 2, 2009 Here you go, Footrest plate to left/right transmission Nm 19 Footrest plate to left of rear frame M 10 screw Nm 36 M 8 screw Nm 19 Footrest plate to right of rear frame M 10 screw Nm 36 M 8 screw Nm 19 Shift lever to footrest plate Nm 35 Andy Link to comment
Phil50 Posted May 2, 2009 Author Share Posted May 2, 2009 Brilliant, thanks very much. Phil Link to comment
