Heyfrank Posted April 28, 2009 Share Posted April 28, 2009 My 04 1150rt 64,000mi has been stalling out. It appears to shut off when handle bars are turned left. Bike running , turn them left the dash goes out and bike shuts off. With just key turned on same thing.If anybody could point me in right direction it sure would help. Thanks Link to comment
T__ Posted April 28, 2009 Share Posted April 28, 2009 Frank, there have been reported problems with the wire harness flexing & the wire breaking in the harness at the tie strap just rearward of the steering neck.. Probably be good place to start looking.. Twisty Link to comment
Heyfrank Posted April 28, 2009 Author Share Posted April 28, 2009 Steering neck, that is just below the headlight cover? it is a T . Should I split the wrap with a knife and check for broken wires? Re wrap with electric tape?Thanks. I have been working on this for awhile and really appreciate the help. Link to comment
T__ Posted April 28, 2009 Share Posted April 28, 2009 Start by grabbing the harness & pulling,, twisting,, & shaking it with the engine running.. If you can reproduce a stall then cut the wire harness covering in the bad area & repair the broken wire with a new piece of wire & proper heat shrink tubing.. Use splice clips & solder the joints.. The problem is usually right at or real close to the tie strap (usually the strap was too tight).. Twisty Link to comment
Heyfrank Posted April 29, 2009 Author Share Posted April 29, 2009 Thanks twisty1 It seems to be around the connection that you mentioned. I spliced the connection but it might need to be a bigger piece. I just put a connector at the break (i hope i did not cut it) and it got better but on pushing higher up it got even better. I will work on it more tomorrow. Link to comment
Heyfrank Posted April 30, 2009 Author Share Posted April 30, 2009 Twisty1, I unwrapped the wires from the covers and wiggled and visually inspected each one with handlebars turned to left. could find nothing yet. As a group the dash comes on and off like there is a brake in the wire. I turned the key on and used a light tester to see if I have current thru each wire. When dash out all wires don:t show current and when the dash is on all wires show current.Does this mean anything? Thanks Link to comment
T__ Posted April 30, 2009 Share Posted April 30, 2009 Frank, try pulling on the wires lengthwise.. The break might be inside the wire covering & not show from the outside.. Pay particular attention to the red wire going in & the green coming out.. Twisty Link to comment
Heyfrank Posted April 30, 2009 Author Share Posted April 30, 2009 might be the green. this is the group going into the key switch. I also noticed that the white clip at the bottom of the unit or where the wire harness is connected has play or is a little loose.I fell like a kid about to get a candy bar. Link to comment
Heyfrank Posted April 30, 2009 Author Share Posted April 30, 2009 I"ts the green. Thank you . I was concentrating on the other batches of wire because when I wiggled them it flickered but was probably hitting the key switch wires. The white connector where the wires go in seems to be ok. I will temporary tie it up and test it out. Once again thank you so much. Link to comment
T__ Posted April 30, 2009 Share Posted April 30, 2009 Frank, let us know what you ultimately find & how our repair it so we have something here for future reference.. Twisty Link to comment
jcguin Posted April 30, 2009 Share Posted April 30, 2009 Hey Twisty, where'd you get the graphic of the wiring? I know its not in my BMW or the Haynes,,,soooooo where'd you get it? Just curious, Jim Link to comment
T__ Posted April 30, 2009 Share Posted April 30, 2009 Jim, you know I can’t tell you that!--- Actually it came straight out of the BMW manual.. Twisty Link to comment
jcguin Posted April 30, 2009 Share Posted April 30, 2009 What page,,,, I didn't see it. I did find a few similar though. Link to comment
T__ Posted April 30, 2009 Share Posted April 30, 2009 I'm not sure without looking but somehwere in the 61.10 to 61.15 range.. Twisty Link to comment
Heyfrank Posted May 2, 2009 Author Share Posted May 2, 2009 test rode the bike 60 miles doing errands , lots of stop and start. No stalling. Basically used a 16-22 wire connector on the broken green wire then used heat shrink . Wrapped back up with electric tape with silicon tape on ends , retied back up. This problem started back on the dealth valley ride in january and finally got bad enough to recreate with turning of handle bars to the left. Twesty1 you amaze me with your dynastic abilities. Link to comment
