Andrew B Posted April 25, 2009 Share Posted April 25, 2009 As a first post, I want to say "hi" to everyone on the board. I have been a lurker for 3 months now since I bought my 2002 R1150RS. I haven't ridden it much as I'm giving her a bit of a fettle and checking everything out. I changed all the lubes, oil / air filters and the plugs and she runs OK. One thing I did notice was the oil pressure light didn't illuminate, so I swapped the bulb, still no light, so I slipped the wire off the switch and grounded it...bingo, light came on. I metered the switch through and works out the switch was U/S. I bought and fitted a new switch and everthings now OK. Being the nosey typre I decided to take the old switch apart using a dremel, inside it I found a little plastic button had swelled slighly causing it to jam in a metal sleeve and this prevented the switch contacts closing again. Anyone else ever had a switch pack up? Link to comment
smiller Posted April 25, 2009 Share Posted April 25, 2009 Not uncommon at all on these bikes. The most common mode of failure is a leak in the diaphragm but I guess there's a thousand ways to die... Link to comment
Andrew B Posted April 26, 2009 Author Share Posted April 26, 2009 The most common mode of failure is a leak in the diaphragm Not nice! I have never had a Smiths or Lucas switch give up. The diaphram appears to be made from thick yellow mylar. I take it that the thread on the switch is M12, if I get hassle again I'll make up an M12 to 1/8" BSP adapter and fit a Smiths, which are 1/3rd the price of the original article. Link to comment
