RoadJunkie Posted April 24, 2009 Share Posted April 24, 2009 Has anyone tried installing a hose joint on the throttle body that would allow easy access for sync? I'm thinking of adding an accessible "T" with a plug (during normal operation) for sync tool connection without removing covers. Link to comment
T__ Posted April 24, 2009 Share Posted April 24, 2009 RoadJunkie, I have one on my R/H TBI.. It comes up under the seat with a plug in it.. You can’t do much with the L/H as it has the evap hose hooked to it.. You need to remove or block off the evap hose to do the balance (can’t just tee it into an extension hose).. BUT,, you can access the L/H evap hose & install your balance gauge hose on the L/H side TBI nipple by using a pair of hemostats (or bent end needle nose pliers) a there is just enough room between the L/H plastic & TBI to access that side without removing plastic panels.. You still have to remove a plastic panel if you need to make a cable adjustment.. Twisty Link to comment
RoadJunkie Posted April 25, 2009 Author Share Posted April 25, 2009 Well, true, you do have to remove the panel to make adjustments, but I have checked the balance several times with no adjustment needed. Guess I'm getting lazy! Thanks, Twisty. Link to comment
