JC120 Posted April 24, 2009 Share Posted April 24, 2009 Could somebody tell me how much brake fluid is used in a brake and clutch bleed. thanks jc120 20041150rt Link to comment
ltljohn Posted April 24, 2009 Share Posted April 24, 2009 I seem to remember using just over a quart for the total brake system and clutch replacement. There are a couple of great threads on these procedures in the M/C FAQ at the top of the page too. Lots of great info there, the info in those threads plus a bit of assistance made the job easy. Wheel Circuit Bleed Control Circuit Bleed Clutch Bleed You may also want to check out the Spring Northeast Tech Day in Connecticut May 2nd Link to comment
philbytx Posted April 24, 2009 Share Posted April 24, 2009 THIS is the stuff I use for both bikes and cars. It comes in Litre cans and you buy one Ate Typ 200 and one Ate Blue. Use the Typ 200 for your first change then the Blue for your second and so on. It makes it VERY easy to see when you have all the old fluid out...goes from gold to blue to gold to blue etc...etc...ad nauseum, ad infinitum Link to comment
NoHeat Posted April 24, 2009 Share Posted April 24, 2009 Two 12-oz cans for the wheel circuits only. A quart plus a 12-oz can if you're also doing the control circuits and clutch. Maybe it can be done with less than that, I don't know. Link to comment
