VladtheImpaler Posted August 21, 2005 Share Posted August 21, 2005 My Ipod is locking up when mounted to the handle bars. It appears to be over heating. Is anyone else having this problem? Has anyone overcome this problem? Russell Link to comment
rocks Posted August 21, 2005 Share Posted August 21, 2005 I have mine just in front of my gas filler attached with velcro to the tank... Works great and no I have not had a overheating problem Link to comment
bmwscoot Posted August 21, 2005 Share Posted August 21, 2005 It MAY be related to heat, but also the beating it takes (vibration-wise) on the bars many times will make it act up. Hard drive based intellegence does not necessarily like the rigid handlebar mounting. When I had my iPod on the bars it would lock up at random times. When I just have it in my jacket pocket inputting ear plug speakers it's fine. When I use my iPod shuffle on the bars, no problem because it is not hard drive based. Link to comment
smiller Posted August 21, 2005 Share Posted August 21, 2005 I wouldn't mount anything with a hard drive to the handlebars, or any other hard mounting without some kind of vibration isolation... almost sure to cause errors reading the drive. Link to comment
russell_bynum Posted August 21, 2005 Share Posted August 21, 2005 I agree with those who are saying it is the vibration from the handlebar mount that is causing your problem. I've ridden in 100+ temps with my iPod in the map case on my tank bag. After a couple of hours in that greenhouse, I can't even hold the thing because it's so hot..but it's never had any problems. I'd suggest moving the device somewhere with more vibration isolation like your tankbag, a jacket pocket, etc. Link to comment
teecro Posted August 21, 2005 Share Posted August 21, 2005 When I had my Sony Mini Dics player attached to front brake master cylinder cover with dual lock Velcro it would skip all the time. Even on very smooth roads. Once I moved it to the RCU dash shelf I never had a problem one with it skipping. Link to comment
Deaner Posted August 21, 2005 Share Posted August 21, 2005 "I've ridden in 100+ temps with my iPod in the map case on my tank bag. After a couple of hours in that greenhouse, I can't even hold the thing because it's so hot..but it's never had any problems." I believe you may kill the screen if you ride that hot too often. I've had my screen go black at high temps in my car. Panic did ensue, my life revolves around perpetual access to massive amounts of music. The cure was about ten minutes in the fridge or freezer. Link to comment
russell_bynum Posted August 21, 2005 Share Posted August 21, 2005 I believe you may kill the screen if you ride that hot too often. I've had my screen go black at high temps in my car. Panic did ensue, my life revolves around perpetual access to massive amounts of music. The cure was about ten minutes in the fridge or freezer. Yeah, I've had that happen once or twice. I just turned it off and left it alone. The next time I thought about it (a day or so later, it was fine. I stopped carrying it in the mapcase, and moved it to the main part of the tankbag and haven't had a problem since. Link to comment
VladtheImpaler Posted August 21, 2005 Author Share Posted August 21, 2005 Thanks, looks like I'll be relocating the thing. Russell Link to comment
tone1298 Posted August 22, 2005 Share Posted August 22, 2005 What type of speaker/earphones are you using? Link to comment
VladtheImpaler Posted August 22, 2005 Author Share Posted August 22, 2005 I use Ultimte Ears in ear speakers. Link to comment
BlueBeemerBoy Posted August 22, 2005 Share Posted August 22, 2005 I killed the hard drive in my Delphi MyFi XM radio by mounting it to the bike. Hard Drives and RTs don't get along very well. Link to comment
ClearwaterBMW Posted August 22, 2005 Share Posted August 22, 2005 speaking of vibration, on my 1200GS yesterday, the BMW Nav ii unit kept doing funny things at 70mph on the road until i realized that the vibration of the bike was causing the sensitive touch screen to be activiated. so this garmin 2610-based gps unit can be messed up by vibration even though it does NOT have the hard drive storage device. greg Link to comment
