cali_beemer Posted April 21, 2009 Share Posted April 21, 2009 So i got my suburban machine peg lowering kit. I went in the gargae to install them, thinking that this should be realtively simple. So I popped one peg off (the brake side) to put the adaptor on. For starters the adaptor marked right doesnt jive with the picture. If I try using the one labeled left then the hole for the return spring is on the opposite side, then not allowing me to put the pin through and the pring not hitting the grooved area. I am baffled of they gave the wrong ones. I can take the peg on and off just fine but just about any way I put these adaptors, there is something not right. Did anyone else have issues? This should be a no brainer, do it in your sleep task. If get the adator on like in the picture then the springs dont go on. I am baffled. If this is the way its designed then its really bad engineering. I looked at the peg and then at the adaptor. The hole for the spring on the peg is to the front, while on the adaptor they are to the back, so I know i am not just delusional but I can see why they dont go on. Can anyone help? Link to comment
Mike S Posted April 21, 2009 Share Posted April 21, 2009 I installed them on my 09 in about 30 min...no problem. You do have to take off the metal collar that helps locate the footpeg rubber. If you don't, you will never get the pivot pin in. If its that difficult, maybe they gave you the wrong ones...passenger pegs perhaps? Link to comment
Motodan Posted April 21, 2009 Share Posted April 21, 2009 Call them....toll free Suburban Machinery Inc. 37127 Ben Hur Ave. Willoughby, Ohio 44094 Phone 1-800-297-1341 They are delightful people who will help you. I've put a number of sets on without a problem other than on a couple where the sidestand made contact when folding up. Took a little grinding to clear. Link to comment
BanjoBoy Posted April 21, 2009 Share Posted April 21, 2009 I'm with Mike, but I think it took me closer to 45 minutes. As I recall, the instructions were correct, and very straight forward. I have an ST, but I think the set up is the same. Good luck, Link to comment
