docwagner Posted August 19, 2005 Share Posted August 19, 2005 Greetings, I ride an LT and have had some problems with shifter linkage failure. I was wondering if this is an issue with R bikes or other K bikes? Link to comment
Lawman Posted August 19, 2005 Share Posted August 19, 2005 Shift linkage problem is probably the most common problem on the LT..I always carried a spare with me when I had my LT. Not a problem on any other bike I'm aware of.. Link to comment
Gandolf Posted August 23, 2005 Share Posted August 23, 2005 And the "shifter linkage problem" is………… Link to comment
Lawman Posted August 23, 2005 Share Posted August 23, 2005 As best I can remember it seemed to be made of light material that consisted of rods and a short ball and socket type connection that would break..I don't think it would be a problem unless it was damaged in a fall or unless it was used by an old Harley rider like myself that uses more force than necessary to change gears..It's just very light material as I recall..Shift gently, don't drop the bike and you MAY not have a problem... Link to comment
