Gregori Posted August 18, 2005 Share Posted August 18, 2005 In getting ready to do the brakes this weekend at the Tech Daze at my house, I went to purchase a couple of bottles of DOT 4. Only problem is - the stores near me don't seem to have it - they sell DOT 3, DOT 5 (which I know is different), and then there's stuff that says 'DOT 3 & 4 compatible' or 'exceeds specifications for DOT 3 & 4.' But nothing marked *just* DOT 4. So I'm here to ask the collective wisdom on this board what the scoop on brake fluid is... IS there just straight DOT 4 available, and is it the same as the above referenced stuff? Thanks! Link to comment
steve.foote Posted August 18, 2005 Share Posted August 18, 2005 Greg, you're good to go. The fluid that meets or exceeds DOT4 is fine. I use Valvoline SynPower high performance brake fluid available at most parts stores. Link to comment
ericfoerster Posted August 18, 2005 Share Posted August 18, 2005 I use Valvoline SynPower high performance brake fluid Ditto what Steve said Link to comment
Joe G Posted August 19, 2005 Share Posted August 19, 2005 Auto Zone carries Castrol GT LMA, which exceeds DOT 4, and is my current fluid-of-choice. It runs about $6/quart. I would steer clear of "house fluids," for no reason other than I think it's false economy. Remember that brake fluid starts to absorb moisture as soon as it's exposed to air, so using fluid that's more than about 4 weeks old will only add a small amount of moisture to your new fluid ( which is why we flush and change in the first place...to get rid of the water moisture in the system ). If you go to a race shop, a superior product is ATE, available in two colors so you know when the new fluid starts to come through the lines, and it usually runs about $10/quart. Vastly superior to Castrol et al, however, because of the higher boiling point ( which translates into less moisture absorption ). Link to comment
jackflash Posted August 19, 2005 Share Posted August 19, 2005 I have a full bottle of DOT 4 in my garage. At least one bottle exists. In getting ready to do the brakes this weekend at the Tech Daze at my house, I went to purchase a couple of bottles of DOT 4. Only problem is - the stores near me don't seem to have it - they sell DOT 3, DOT 5 (which I know is different), and then there's stuff that says 'DOT 3 & 4 compatible' or 'exceeds specifications for DOT 3 & 4.' But nothing marked *just* DOT 4. So I'm here to ask the collective wisdom on this board what the scoop on brake fluid is... IS there just straight DOT 4 available, and is it the same as the above referenced stuff? Thanks! Link to comment
Steve_Witmer Posted August 19, 2005 Share Posted August 19, 2005 Castrol GT-LMA is the way to go if you want to avoid a trip to the dealer for "genuine BMW" brake fluid. Good stuff and available almost everywhere. Do not use DOT 5 brake fluid. Link to comment
Ken H. Posted August 19, 2005 Share Posted August 19, 2005 Remember that DOT5 is silicone based and not compatible with DOT3 or DOT4. DOT 5.1 is not silicone based. Link to comment
