-patrick Posted August 18, 2005 Share Posted August 18, 2005 Has anyone replaced the two H3 fog lamp bulbs with a HID kit? This would seem to be "less illegal" then replacing the headlight bulb. How did it turn out and which kit did you use? I've been thinking of ordering from these folks: http://www.xenondepot.com/ Best, -patrick -- 2004 R1150RT 1994 R1100RSL 1968 TR6R Link to comment
beemerman2k Posted August 18, 2005 Share Posted August 18, 2005 Great question. Here's another: can I replace my PIAA 1100XX lights on the mount from CycleGadgets.com with Xenon units? Link to comment
skinny_tom (aka boney) Posted August 18, 2005 Share Posted August 18, 2005 I replaced the low beam with an HID. The fog light pattern is very focused and provides a horizontal "slot" of light that lands shy of the horizon on your low beam. It will also cost you half as much for the low, if you only buy one bulb/ballast or split a kit. With the HID low beam, I can hardly tell if my fog lights are even on. I split a kit with another board member, so the cost was pretty good, and I have no idea where it came from. Sorry... Link to comment
Les is more Posted August 19, 2005 Share Posted August 19, 2005 Here's a discussion that might be enlightening for both you and Patrick. Link to comment
RapidDog Posted August 19, 2005 Share Posted August 19, 2005 Do i smell a group buy? The folks at Xenonfactory set us up at the Pelican R1100S forum with a pretty good deal. My ow beam HID is fab! Link to comment
