Jim Moore Posted February 11, 2009 Share Posted February 11, 2009 I have an 02 GS with over 98K miles. I plan to keep it until 200K miles. I have read that the u-jonts in the driveshaft are somewhat prone to failure in high-mileage bikes, so I bought a spare (used) driveshaft. Now I'm wondering if it would be worthwhile to have the u-joints rebuilt and replace my current driveshaft with the used / rebuilt one. So, two quick questions. 1. Can the u-joints be rebuilt? 2. Is it worthwhile? Thanks, Link to comment
smiller Posted February 11, 2009 Share Posted February 11, 2009 I'm not sure that the u-joints could really be called prone to failure, but when they do fail it can be catastrophic so I would consider it good advice to take some preventative action when you get much above 100k. To my mind simply replacing the original driveshaft with a good, low-miles used unit should be fine but there are places that can rebuild the driveshaft if you insist on brand-new u-joints. The other factor to consider is aging of the rubber damper that joins the two driveshaft halves but I consider this less of an issue because these failures are relatively uncommon and usually non-destructive if they do occur, and also that particular failure seems to be more related to infant mortality than long-term aging. Link to comment
bmwmick Posted February 11, 2009 Share Posted February 11, 2009 Machine Service Industry 100 Ashwaubenon St. Green Bay, WI 54304 Attention: Mitch 1 800 677 8711 Mick Link to comment
Jim Moore Posted February 11, 2009 Author Share Posted February 11, 2009 Hey Mick, Thanks, thanks, and thanks. You too, smiller. Link to comment
DavidEBSmith Posted February 12, 2009 Share Posted February 12, 2009 You know, there's a similar discussion happening on Internet BMW Riders as we speak. What an odd coincidence. Link to comment
