kdiver Posted February 8, 2009 Share Posted February 8, 2009 I have mounted my garmin zumo and now I would like help on connecting the electrical power. I found what looks like an unused circuit terminated on the frame in front under the headlights. The square terminal appears to have a cap on the end. Is this in fact a spare terminal and are special connectors required. If so, where can they be purchased. 2006 R 1200 RT. Thanks in advance for any help and suggestions! Link to comment
hopz Posted February 8, 2009 Share Posted February 8, 2009 Congratulations, you have found the elusive BMW GPS Plug. Yes there is a plug/cable available. It is called a Maintenance plug, and the part number is floating around this Forum, or also look on the Zumo Forums as well: http://www.zumoforums.com/index.php?action=forum Link to comment
kdiver Posted February 8, 2009 Author Share Posted February 8, 2009 Thanks for the help. This forum is impressive. Link to comment
Effjay Posted February 8, 2009 Share Posted February 8, 2009 Do an extended (2-3 year) search for P/N 83300413585 (or "Repair Connector"). Cost is about $20 Jeff Link to comment
Sailorlite Posted February 8, 2009 Share Posted February 8, 2009 My dealer couldn't find his -585 cables so sold me a 61.11.0.415.843 cable instead. The 843 is evidently commonly used on the Authority bikes and is longer and more expensive than the 585 - so don't get it unless that's all that's available. Link to comment
99Roadster Posted February 8, 2009 Share Posted February 8, 2009 We only need to go as far as the Archive for Hexhead Maintenance and Parts thread. Accessory Front Power Take Off Connector (e.g for a GPS) - 83 30 0 413 585 Link to comment
kdiver Posted February 8, 2009 Author Share Posted February 8, 2009 thanks to everyone...found the part at chicago bmw. will order tomorrow. $16. question #2. how can you connect the zumo audio out to the aux input on the oem radio (2006 r 1200 rt) the selector shows an aux on the screen when a scan. question #3 what about connecting headphones to radio Link to comment
