namtinker Posted August 11, 2005 Share Posted August 11, 2005 Hi guys Any idea where I can find fuel disconnects in Canada? The Touratech ones looks ideal, gettting them here expensive though! Link to comment
Marty Hill Posted August 11, 2005 Share Posted August 11, 2005 Curious, what are you referring to? Link to comment
Paul Mihalka Posted August 11, 2005 Share Posted August 11, 2005 Talking of fuel disconnects that disconnect the lines when you want to take the tank off, and automatically shut off the lines so no gas is spilled. You can get them as original BMW parts from a BMW dealer, including mail order from USA or England. I don't like them. They can break. BMW parts are plastic. I understand there are some metal ones available that don't break. Wunderlich? Link to comment
Marty Hill Posted August 11, 2005 Share Posted August 11, 2005 Hi Paul, I've had my tanks off about 10 times. Never a problem. I think the plastic ones will be fine over time. time will tell. Link to comment
Emoto Posted August 11, 2005 Share Posted August 11, 2005 I haven't had my r1200gs tank off yet. Are there quick disconnects on it from the factory, or what? Link to comment
David Posted August 11, 2005 Share Posted August 11, 2005 I haven't had my r1200gs tank off yet. Are there quick disconnects on it from the factory, or what? As Marty said, it's really easy. Mine haven't leaked any yet. One nice advantage is that no tools are required (for the disconnects themselves). The disconnects are right at the junction with the fuel pump/filter assembly. Pop 'em off, swing them out of the way, and remove the tank. It's wonderfully easy. As I recall, it's one bolt on the tank, and four quick tube disconnects. Kind of nice if you ever needed to do it by the side of the road. Link to comment
Marty Hill Posted August 11, 2005 Share Posted August 11, 2005 David, One bolt on each side...unless I've been doing something unnecessary, which is always a possibility. Link to comment
Marty Hill Posted August 11, 2005 Share Posted August 11, 2005 Emoto, Two disconnects on the right/2 hoses to pull off. Just press in the metal tabs and pull away. Twist the black cover on the left and remove. On the left 2 plugs...insert finger nail inside the metal piece in the rear and pull off. One more press disconnect. Do the 2 hex bolts and slide the tank a bit toward the rear and find a place to put it. You did run most of the gas out first? Any problems, don't call me...call David! Link to comment
Emoto Posted August 11, 2005 Share Posted August 11, 2005 Thanks guys! Are these quick disconnects the kind that blocks the flow when disconnected, or do I still need to have a bucket handy? Link to comment
Marty Hill Posted August 11, 2005 Share Posted August 11, 2005 Have a small rag. A few drops may show up. One or two at the most. Link to comment
David Posted August 11, 2005 Share Posted August 11, 2005 One of the things I really enjoy about the GS is how quickly you can get it nekkid. From start to finish, you can get it looking like this in less than 5 minutes. It's a beautiful thing when you need to do work on it: Link to comment
steveknapp Posted August 23, 2005 Share Posted August 23, 2005 FYI: http://bmwsporttouring.com/ubbthreads/showflat.php?Cat=0&Number=552301 Also the o-rings can tear/leak if you're not careful. And more than one person has been "stranded" because these came apart. Link to comment
