jskene Posted August 11, 2005 Share Posted August 11, 2005 I just bought a '98 K12, and find the brakes to be much less responsive than my '94 K11. The K11 has new pads, and K12 presumably still has the originals - 14K miles. Do you know if the stock BMW pad ages to the point of not being responsive? Brake fluid has been changed recently on both, so that is not a factor. Link to comment
Calvin (no socks) Posted August 11, 2005 Share Posted August 11, 2005 Hi, if the pads/rotors have a light rust film, or have been contaminated with cleanig agent etc... then reduced performance may be a result... remove and inspect, clean rotors, clean or replace pads... Then you must break in the new pads.... Which will have reduced performance until properly worn in.... Link to comment
