FREEBEE Posted August 8, 2005 Share Posted August 8, 2005 ...Is alot more fun that my old H-D Where is the front suspension adjustment? The riders manual indicates it is right in front of the left Cyl? Link to comment
kioolt Posted August 9, 2005 Share Posted August 9, 2005 To my knowledge there is no front suspension adjustment on an 1150RT. Maybe I'm wrong, if there is one I'd like to know too. Link to comment
FREEBEE Posted August 9, 2005 Author Share Posted August 9, 2005 You may be "On To Something" there... Pg.36 in my 2002 1150RT Riders manual (US) indicates an adjustment screw for the Rear shock. While pg.37 indicates the suspension spring preload. I can't seem to locate the shock adjustment screw Link to comment
bmwmick Posted August 9, 2005 Share Posted August 9, 2005 Marc, The REbound adjustment screw is just above the lower mounting bolt in this diagram: http://tinyurl.com/8fjdr HTH, Mick Link to comment
Michael Fajans Posted August 9, 2005 Share Posted August 9, 2005 On the left side metal foot peg plate there is a small hole behind which there is an adjusting screw for which you will need an extra long screwdriver and a flashlight. Link to comment
FREEBEE Posted August 9, 2005 Author Share Posted August 9, 2005 Thanks! Unbelievable..I'm looking for it in front of the left cylinder,and not having much luck Well on the lighter side, I now know how to remove and reinstall the tupperware. Ok if we keep this our little secret?? Link to comment
