Vosper Posted December 30, 2008 Share Posted December 30, 2008 Hey folks, I have a 99 R1100GS (new to me) and wanted to adjust the controls on the handlebar a bit. An old flight instructor once told us there were no stupid questions, only stupid students. This may fall into that category, but... I wanted to rotate my switch housings a bit - mostly to try to get the horn button closer to my left thumb. It seems there is a bolt connecting the middle section of the handlebars to either switch housing. If that's the case, then I guess the only way to rotate the switch housings is to rotate the entire handlebar? Thanks in advance for any clarification. Link to comment
knight88 Posted December 31, 2008 Share Posted December 31, 2008 I'm sure there is a bolt holding the switch/control assembly maybe someone here can point you in the right direction to the instructions on loosening them. Link to comment
Ken H. Posted December 31, 2008 Share Posted December 31, 2008 Described a bit more accurately, there is an index pin that hold the controls at a fixed point. To prevent unintentional rotation. You can disassemble the control and file off the pin if you want. Link to comment
