Skywagon Posted December 27, 2008 Share Posted December 27, 2008 I have a 2005 R1150RT. I am purchasing an Odyssey PC680 battery for a replacement this week. One of the web sites suggest I buy a pair of cable adaptors to make it easier on BMW bikes. It looks just like a small piece of copper in the shape of an L. Does the PC680 fit as is or do I need these cable adaptors? Thanks. Link to comment
ltljohn Posted December 27, 2008 Share Posted December 27, 2008 Without the adapters you will have to bend the cable ends on the bike. It is easier if you just get the adapters or make some using a bit of copper pipe. Link to comment
Skywagon Posted December 27, 2008 Author Share Posted December 27, 2008 Thanks..will order them. Link to comment
Dans08 Posted December 27, 2008 Share Posted December 27, 2008 Without the adapters you will have to bend the cable ends on the bike. It is easier if you just get the adapters or make some using a bit of copper pipe. You have my attention. I've been wanting to get the extension. How do you make them from copper pipe. I just happen to have some 1/2" dia copper pipe laying around. Would this work and what would be the dimensions to make them? Link to comment
LGannon Posted December 27, 2008 Share Posted December 27, 2008 its just an L shaped piece of copper with two holes in it Link to comment
smiller Posted December 27, 2008 Share Posted December 27, 2008 I just bent the existing terminals flat with a pair of pliers, took about 30 seconds. They fit perfectly that way and you'll avoid a bunch of unnecessary hardware in your battery connections. Link to comment
upflying Posted December 27, 2008 Share Posted December 27, 2008 its just an L shaped piece of copper with two holes in it Here's what I did. Link to comment
swfraley Posted December 27, 2008 Share Posted December 27, 2008 If you mount the battery sideways, you don't have to bend or buy anything. Link to comment
Dans08 Posted December 27, 2008 Share Posted December 27, 2008 Is that battery laying on it's side in that picture? Or, is that shot looking forward at the side of the battery? Link to comment
Ken H. Posted December 28, 2008 Share Posted December 28, 2008 Is that battery laying on it's side in that picture? Or, is that shot looking forward at the side of the battery? The above photo is with the battery in its original terminals up position with adaptors. With it laying on its side, terminals to the left, no adaptors are needed. The Odyssey is an AGM battery so its orientation doesn’t matter. Link to comment
Selden Posted December 28, 2008 Share Posted December 28, 2008 With it laying on its side, terminals to the left, no adaptors are needed. The Odyssey is an AGM battery so its orientation doesn’t matter. Ken, are you saying that there is enough room under the tank for the battery to be on its side, presumably with the terminals facing the rear? I had the plastic off yesterday to check electrolyte level (really low), but I don't remember how much room there was in there, but side mounting would make everything much easier. Eventually the current battery will fail, and I'll probably replace it with a PC680; in the meantime, adding 6 oz of distilled water to the electrolyte appears to have rejuvenated it. I still don't understand why BMW can't make an AGM battery standard equipment on a $15,000 motorcycle -- especially when the battery is in such a difficult location to service. Link to comment
FrankT Posted December 28, 2008 Share Posted December 28, 2008 If you mount the battery sideways, you don't have to bend or buy anything. +1 for the sideways installation. Link to comment
breyfogle Posted December 28, 2008 Share Posted December 28, 2008 Its hard to tell from the picture but isnt the (+) terminal connection WAY too close to the battery tray. Hope there is no path to ground ! Link to comment
ron c Posted December 28, 2008 Share Posted December 28, 2008 Skywagon, My PC680 came with the 2 copper brackets. No additional purchase was required. The PC battery is slightly shorter, as in not as tall, than the OEM battery on my '04 RT. This sounds like a good thing but the rubber hold down strap was then too long to provide any hold down tension on the new battery. I raised up the battery by sliding in some wood blocks under the battery. Regards, Ron Cooper Round Rock, Tx. Link to comment
Skywagon Posted December 28, 2008 Author Share Posted December 28, 2008 Thanks Ron C. Do you recall how much wood you needed? 1/8, 1/4, more? Link to comment
ESokoloff Posted December 29, 2008 Share Posted December 29, 2008 Thanks Ron C. Do you recall how much wood you needed? 1/8, 1/4, more? I WOOD think that the spacer would be the thickness of the difference in height between the old/new battery. Link to comment
breyfogle Posted December 29, 2008 Share Posted December 29, 2008 Thanks Ron C. Do you recall how much wood you needed? 1/8, 1/4, more? I did something similar by using 4 self-sticking rubber bumper thingys (intended as feet for small do-it-yourself electronic project boxes) stuck onto the battery tray. Added about 1/4 inch to the height of the battery and looked better than a piece of wood. Link to comment
upflying Posted December 29, 2008 Share Posted December 29, 2008 Its hard to tell from the picture but isnt the (+) terminal connection WAY too close to the battery tray. Hope there is no path to ground ! Good spot. Yes, I have had an occasional arc welder surprise when removing the battery but there is enough clearance in normal use to prevent a direct short. Link to comment
ron c Posted December 29, 2008 Share Posted December 29, 2008 Skywagon, I raised mine 3/8 inch. Ron C. Link to comment
