Dave_W Posted December 24, 2008 Share Posted December 24, 2008 Hi there, Going in for my 12,000 miles on my 08 1200RT. Should I have the FD fluid changed? David Link to comment
Firefight911 Posted December 24, 2008 Share Posted December 24, 2008 Two thoughts - 1 - Do it your self 2 - Get Help on your first go 'round. Now, the BEST part!!!!! All of the above are available in your neighborhood!!!!!!!!!! Here's a pictorial with, selfishly speaking, some great info on the topic - LINKY And here is the "in the neighborhood" part - TECH DAY Now, to answer your question - Yes!!!!! Change it. 600, 6000, 12000, and every 12000 thereafter is my regimen. Hope this helps!!! Link to comment
Twisties Posted December 24, 2008 Share Posted December 24, 2008 Two thoughts - 1 - Do it your self 2 - Get Help on your first go 'round. Now, the BEST part!!!!! All of the above are available in your neighborhood!!!!!!!!!! Here's a pictorial with, selfishly speaking, some great info on the topic - LINKY And here is the "in the neighborhood" part - TECH DAY Now, to answer your question - Yes!!!!! Change it. 600, 6000, 12000, and every 12000 thereafter is my regimen. Hope this helps!!! I'm doing the regimen Phil suggests. We have two. At 12,000 one was clean as can be, the other had a fair amount of metal on the magnets. We'll see about 24,000 this spring. If you get two good clean changes in a row you could probably extend the interval to 24,000 if you really feel so inclined, since BMW only requires the one at 600 miles. Link to comment
Exploreinman Posted December 24, 2008 Share Posted December 24, 2008 I've spoken with several BMW mechanics at different dealerships and they unanimously say to change every 12,000 miles. I didn't get to mine until 18,000 miles, but the oil was very clean. I'll be changing every 12,000 from now on. Link to comment
Silver Surfer/AKAButters Posted December 24, 2008 Share Posted December 24, 2008 I'm doin' what Phil said, myself. Cheap insurance. Link to comment
terryofperry Posted December 24, 2008 Share Posted December 24, 2008 I change mine at every oil change. Kinda crazy I know. Ten minute job, a quart will do almost five changes. Ride safely Terry Link to comment
rglassma Posted December 24, 2008 Share Posted December 24, 2008 Absolutely... Cheap insurance.. Every 12K ..... If you want to do it yourself, there are great "how tos". If not, have the dealer do it at each 12K service. Link to comment
Semper_Fi Posted December 24, 2008 Share Posted December 24, 2008 I change mine at every oil change. Kinda crazy I know. Ten minute job, a quart will do almost five changes. Ride safely Terry I do the same thing - for the effort and cost it is a no-brainer Link to comment
Mister Tee Posted December 24, 2008 Share Posted December 24, 2008 I did mine at 15,000 miles, and the oil had a foul, burnt smell to it and it was pitch black. That convinced me that routine final drive oil changes probably should be done. And doing it was really no big deal. Link to comment
keithb Posted December 24, 2008 Share Posted December 24, 2008 Dave I do mine at 12K mile intervals and DON'T FORGET TO GREASE YOUR SPLINES AS WELL. At 12K and 24K miles the splines definitely needed grease. They were quite dry. The 36K service is coming up in 3K miles and I don't expect it to be any different. Link to comment
Semper_Fi Posted December 25, 2008 Share Posted December 25, 2008 Dave I do mine at 12K mile intervals and DON'T FORGET TO GREASE YOUR SPLINES AS WELL. At 12K and 24K miles the splines definitely needed grease. They were quite dry. The 36K service is coming up in 3K miles and I don't expect it to be any different. Excellent point for all, especially on the newer style drives that do not require the drive end to be dropped to drain. Link to comment
