FlyingFinn Posted December 13, 2008 Share Posted December 13, 2008 Does anyone have, or know where to find, the pinout of oilhead flasher relay? I don't have the fuse box, simply direct connections to the flasher relay itself and with the "BMW style" turn signal switchgear the connections are not obvious. Appreciating any and all help! -- Mikko Link to comment
T__ Posted December 13, 2008 Share Posted December 13, 2008 Mikko, what bike,, ( model, year) would this be needed for? Twisty Link to comment
FlyingFinn Posted December 13, 2008 Author Share Posted December 13, 2008 Lets say the relay is from a 1100RT. AFAIK, the fuse boxes are same for 1100RT and 1150RT. Extrapolating from there I made an assumption (should have known better...) that all oilheads (except for R1100S which uses completely different electrics) use same flasher relay. The relay will not be used in a 1100RT -- Mikko Link to comment
T__ Posted December 13, 2008 Share Posted December 13, 2008 Mikko, well, I hope someone else here has something better for you.. I have the 1100 in book form that is spread over about 4 pages with no pin numbers but circuit wire colors & switches shown.. Only problem is my scanner is out for repair so I have no way of making an electronic copy.. With no switch or flasher unit pin numbers shown I can’t even tell you what goes where as you & I would have no common reference.. The only thing I have in electronic form that I can find is the 1150 GS.. This will probably help you out,, only problem is I can barely read the document on my computer & when I try to shrink it enough to send it electronically is looks to be difficult to see pin numbers.. If you E-Mail me or PM me your E-Mail address I will send you the page in .jpg form.. Not sure it will be real readable but it might print out OK (worth a try I guess).. Lots of wires on that flasher unit so you really need to see the schematic in person.. Twisty Link to comment
FlyingFinn Posted December 13, 2008 Author Share Posted December 13, 2008 Thanks Twisty, I got the jpegs and it's quite readable. Only the flasher pin numbers/pin names are little fuzzy, can you verify those for me? From what I see it goes something like this (from left to right) Pin 1, can't read the name (switched +12V from load release relay) Pin 2, can't read the name (12+ directly from battery) Pin 3, TL (left turn switch) Pin 5, WB (4-way switch) Pin 4, TA (turn signal cancel) Pin ?, TR (right turn switch) Pin 12, L (left blinkers) Pin ?, R (right blinkers) Pin 7, Ground Thanks again! -- Mikko Link to comment
Andy Johnston Posted December 13, 2008 Share Posted December 13, 2008 Thanks Twisty, I got the jpegs and it's quite readable. Only the flasher pin numbers/pin names are little fuzzy, can you verify those for me? From what I see it goes something like this (from left to right) Pin 1, can't read the name (switched +12V from load release relay) Pin 2, can't read the name (12+ directly from battery) Pin 3, TL (left turn switch) Pin 5, WB (4-way switch) Pin 4, TA (turn signal cancel) Pin ?, TR (right turn switch) Pin 12, L (left blinkers) Pin ?, R (right blinkers) Pin 7, Ground Thanks again! -- Mikko Hi Mikko these are the pin no.s / names from a haynes manual for 1150rt 1-15e 2-30 3-TL 4-TA 5-WBT 6-R 7-31 8-TR 12-L Cheers Andy Link to comment
T__ Posted December 13, 2008 Share Posted December 13, 2008 Mikko Pin 1, can't read the name (switched +12V from load release relay)___ (looks like 1SE, OR 15E) Pin 2, can't read the name (12+ directly from battery)___ (looks like 30U) Pin 3, TL (left turn switch)__OK Pin 5, WB (4-way switch)__OK Pin 4, TA (turn signal cancel)__OK Pin ?, TR (right turn switch)__OK Pin 12, L (left blinkers)__OK Pin ?, R (right blinkers)__OK Pin 7, Ground__OK Twisty Link to comment
FlyingFinn Posted December 13, 2008 Author Share Posted December 13, 2008 Thanks both, that should do it. (Gotta love this board!) -- Mikko Link to comment
