JerryMather Posted November 25, 2008 Share Posted November 25, 2008 A R75/5 showed up for service and I need to know everything needed for a minor service. Wt & ammount of oil in final drive, valve clearances, Wt of engine oil and anything else I should be looking at on one of these. Where's the oil filter located? Do I need to drop the pan to get to it? Thanks in advance, Link to comment
Paul Mihalka Posted November 25, 2008 Share Posted November 25, 2008 I don't have oil volumes in my head. Valve clearance was .006" for intake, .008" for exhaust. The oil filter is on right side front of the engine, under a triangular cover with 3 bolts. Watch out for the O-ring gasket in there. If pinched the engine will not have oil pressure. There is a airheads.org web site that I'm sure has all the information you need. Link to comment
JerryMather Posted November 25, 2008 Author Share Posted November 25, 2008 Thanks Paul Link to comment
StuGotz Posted November 25, 2008 Share Posted November 25, 2008 Beav, 20/50 2-1/4 qts As paul said watch o ring on oil filter. Idle 600-880 rpm plugs Bosch w200t30 2 ea Intake .15mm/.006" Exhaust .20mm/.008" compression 130psi gear oil 90w .8ltr/1.7pts rear drive 90w .15ltr/.32pts final drive 90w .25ltr/.53pts fork oil 10w .28/.59 per leg petcock screens remove every 10k miles clean crud, dump water from tank. good luck MB> Link to comment
