RockLives Posted August 3, 2005 Share Posted August 3, 2005 I am going to deep six my 2004 1150RT Gel Battery. I will be installing an Odyssey with L bracket terminal connectors this week. Which covers do I need to remove? Any other info? thanks Link to comment
Ken H. Posted August 3, 2005 Share Posted August 3, 2005 The left side faring has to come off. Then the battery will slide out to the left. Link to comment
leikam Posted August 3, 2005 Share Posted August 3, 2005 You may end up wanting to raise the tank at some point to get clearance. If you do, you'll need to pull the right side too. Link to comment
Larsen Posted August 4, 2005 Share Posted August 4, 2005 Why would you need to remove the right side fairing or raise the tank. Everything will slide out the left side or is there something very different with the 04 model that I haven't heard about? Link to comment
kioolt Posted August 4, 2005 Share Posted August 4, 2005 Remove the left fairing panel then remove the air intake tube and the battery will slide out. There is no reason to remove the right fairing panel. Link to comment
akasjl Posted August 4, 2005 Share Posted August 4, 2005 No need to remove the right side fairing period. Link to comment
RockLives Posted August 4, 2005 Author Share Posted August 4, 2005 TY all It will be done this weekend.. Link to comment
BFish Posted August 4, 2005 Share Posted August 4, 2005 at my 600mi service the battery died as i was picking up the bike. they put new gel battery in and i was able to watch. left side tupperware removed dead batt slid out and new one slid in. a little wiggling, but it didn't look difficult. Link to comment
Green RT Posted August 5, 2005 Share Posted August 5, 2005 I don't know about 1150s but on the 1100s there is one point that I didn't see mentioned. After pulling left tupperware and air intake tube, disconnect the cable to the left side of the battery. Slide it out, then disconnect the cable to the right side. You won't be able to access the right side cable until it is halfway out. Link to comment
