Breitie Posted August 2, 2005 Share Posted August 2, 2005 Have received letter from BMW advising recall of my 2002 model R1150RT. What is the problem? Link to comment
jemllc Posted August 2, 2005 Share Posted August 2, 2005 I think it has something to do with possible crimping of fuel lines from the gas tank. Link to comment
Redbrick Posted August 2, 2005 Share Posted August 2, 2005 Breitie. I have an '04 1150 that was called in for a possible fuel line problem, fuel line clamps or something, as Jim mentioned..The previous owner took care of it with the dealer....Curious......Did the notice actually use the word "recall"?...I had heard that BMW was using some politically correct statement rather than the nasty "R" word..... Phil..........Redbrick Link to comment
WyreNut Posted August 3, 2005 Share Posted August 3, 2005 Doesn't BMW use the word "Campaign" or some such? I've had 3 of them on my '04 RT so far... WyreNut Link to comment
smiller Posted August 3, 2005 Share Posted August 3, 2005 I think there's also a recall out that provides an updated crown bearing for the final drive, and also one for a free check to ensure that your transmission housing is aligned properly so as to avoid a premature spline failure. Link to comment
Willie Posted August 3, 2005 Share Posted August 3, 2005 Are these recent recalls? Could I call my dealer to find out if anything needs done to my '02? I bought it used so I hope they wouldn't give me a hard time about it. Maybe the fuel line clamps at the tank are the cause of the weird noise that developed sometimes when I turn the key and the pump kicks on. Guess I'll have to call them. So how many recalls are there now on the '02 and what are they? Thanks, Terry Link to comment
RussInParis Posted August 3, 2005 Share Posted August 3, 2005 I don't know, but I just heard that BMW is doing some sort of "verification" of all 260,000 BMWs equipped with assisted brakes (ABS III). I found this on a french site: http://afmb.fr/ but if true it should be coming out on english sites as well. Maybe that's it? Russ Link to comment
Ken H. Posted August 3, 2005 Share Posted August 3, 2005 You, Sir, are evil. Yes indeed. And just for the sake of those less, uh, "initiated" on this board, who may be reading this thread, Mr. Seth Miller, "smiller" is yanking your chain. Link to comment
rdsmith3 Posted August 3, 2005 Share Posted August 3, 2005 Go here: NHTSA Read this: Make : BMW Model : R SERIES Year : 2002 Manufacturer : BAYERISCHE MOTOREN WERKE NHTSA CAMPAIGN ID Number : 04V028000 Mfg's. Report Date : JAN 15, 2004 Component: FUEL SYSTEM, GASOLINE:DELIVERY:HOSES, LINES/PIPING, AND FITTINGS Potential Number Of Units Affected : 39000 Summary: ON CERTAIN MOTORCYCLES, THE O-RING IN FUEL LINE QUICK-DISCONNECT COUPLING COULD BECOME DAMAGED AND LEAD TO A FUEL LEAK. THERE IS ALSO A PROBLEM INVOLVING CRIMP-TYPE HOSE CLAMPS, WHICH CAN RESULT IN A FUEL LEAK. Consequence: FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE COULD RESULT IN A FIRE. Remedy: DEALERS WILL INSPECT AND, IF NECESSARY, ADJUST ALL CRIMP-TYPE HOSE CLAMPS. ALSO, ALL FUEL LINE QUICK-DISCONNECT COUPLINGS WILL BE INSPECTED. IF A LEAK IS DETECTED, THE QUICK-DISCONNECT O-RING WILL BE REPLACED. IF DAMAGED, THE COUPLING WILL BE REPLACED. OWNER NOTIFICATION BEGAN ON APRIL 30, 2004. OWNERS SHOULD CONTACT BMW AT 1-800-831-1117. Notes: CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236). But this is over a year old. Did you just get this letter? Link to comment
Stan Walker Posted August 3, 2005 Share Posted August 3, 2005 And just for the sake of those less, uh, "initiated" on this board, who may be reading this thread, Mr. Seth Miller, "smiller" is yanking your chain. Surely your pulling my leg.... I was virtually on my way to the dealer to get a new crown wheel bearing and seal, guess not, huh? Stan Link to comment
smiller Posted August 3, 2005 Share Posted August 3, 2005 And just for the sake of those less, uh, "initiated" on this board, who may be reading this thread, Mr. Seth Miller, "smiller" is yanking your chain. Hey... now just what do you mean by 'initiated'..? On second thought, nevermind... Link to comment
Breitie Posted August 3, 2005 Author Share Posted August 3, 2005 Thanks for this accurate, factual and constructive feedback. I only received the recall letter, titled 'BMW Motorcycle - Recall Action' and dated 19th July 05 two weeks ago from BMW Motorrad Australia. I am relived that it is nothing more serious. I have had the fuel tank off many times, as well as the pump unit out to change the fuel filter, and marvelled at those dodgy hose clamps myself, but did not detect a leak. One has to be very careful when 'clicking' the quick connectors together to not dislodge the O rings. I find a little bit of Vaseline helps the things snap together smoothly and securely. Link to comment
Ken/OC Posted August 4, 2005 Share Posted August 4, 2005 I think there's also a recall out that provides an updated crown bearing... My dealer said they expect another notice of recall for the RTs within 30 days for installation of the spline autolube device. This has been aftermarket until now, but BMW evidently bought the company making it. Link to comment
