r77toy Posted November 14, 2008 Share Posted November 14, 2008 What filters use the same wrench as oem? Link to comment
NoHeat Posted November 14, 2008 Share Posted November 14, 2008 It's a common wrench size for automobile filters, so there are probably many. For the two filters I've tried that fit the bike, Mobil 1 fits the same wrench, but NAPA Gold does not. Of course you can take your wrench with you to the autoparts store when you're shopping for a filter. Link to comment
Unhofliche_Gesundheit Posted November 14, 2008 Share Posted November 14, 2008 of course you saw the sticky with all the parts at the top of the list? i found going to autoparts place (with my filter wrench/socket thingee) and the list was problematic they had some of the filters on the list but did not work w. the wrench. i walked away empty handed (well except for the autolite sparkplugs). i went to a honda motorcylce shop and they easily found me a filter for 10$ instead of 30$, that had the correct flute pattern. the local bmw dealer (who also does Kawi) only seems to have the bmw filter. i bought one once and can say it seems superior - more hefty- and the fit of the wrench is very nice. the fit is important for removal - needs to be good fit as for some reason filters go on loose but come off tight. the point: not the end of the world if you do buy from dealer. time hunting for a filter is money too. the filter is very recessed once installed and you dont want the old one getting stuck in there due to lack of a good fit on the wrench. peace of mind and making job easy also have worth. you could buy a cheap filter and a new wrench for less money than the bmw filter but i have not had good luck with the cheap plastic wrenches. i have only done 2 oil changes on this bike so experts may wade in with more/better opinions. cheers. oh and Link to comment
moshe_levy Posted November 14, 2008 Share Posted November 14, 2008 It would help to know your model and year, but Beemerboneyard sells Bosch filters http://www.beemerboneyard.com/oilfilters.html which are an exact fit. I've been using them on my RT and on the wife's R for some time now. A pack of six goes for about $45, or roughly what two OEM filters would cost. I have not seen anything negative about Bosch oil filter quality vs. OEM, so I see it as a good place to save some $$$. -MKL Link to comment
Paul Mihalka Posted November 14, 2008 Share Posted November 14, 2008 The Purolator L10241 oil filter seems to be good quality among the cheapo filters (+/- $3.00) and fits the stock BMW filter wrench. Link to comment
philbytx Posted November 14, 2008 Share Posted November 14, 2008 FYI - The Bosch Oil filter I just received for my oilhead was, GASP!, Made in the USA :clap: Link to comment
tallman Posted November 14, 2008 Share Posted November 14, 2008 This information may be helpful. http://motorcycleinfo.calsci.com/Filters.html#buy There is so much more involved than fit. Some filters will bypass and circulate more crud. Some trap more and still filter and flow rate is OK. Best wishes. Link to comment
Dave in Doodah Posted November 14, 2008 Share Posted November 14, 2008 Excellent reading - thanks much tallman. Link to comment
