lawnchairboy Posted November 10, 2008 Share Posted November 10, 2008 I managed to put a switched fuse block into my RT which has miraculously functioned flawlessly since installing a couple of years ago. I only run a gerbings power cord and autocom power lead off this as of now. I am considering adding HID aux lighting. The STOOPID questions: If one were to desire running the HID aux lights all the time, could one just wire direct to the fuse block? Would you need to have a separate relay for the aux lights (the fuse block I would be connecting to already has one)? Said fuse block is tied to keyed power via a relay and is fuse protected to battery so key on=fuse block on. what spec would you look at on the aux lights to determine proper fuse for said lights? TIA chris Link to comment
johnlt Posted November 10, 2008 Share Posted November 10, 2008 There will be some that say to run seperate relay but for two HIDs at 35W each, I think your fuse block would be fine. If running seperately, a 10 amp fuse would be adequate. Link to comment
sundaeman Posted November 11, 2008 Share Posted November 11, 2008 I installed a separate relay for the HIDs and ran the relay switch power through the switched block. I did the same thing for my Motolights. Link to comment
Sheepherder Posted November 11, 2008 Share Posted November 11, 2008 some useful info and they also sell the relays ect. shows how the do the wiring and also the wire sizing PM me if you have any questions http://www.rallylights.com/Useful_Info.aspx http://www.easternbeaver.com/ Link to comment
