travelinman Posted August 1, 2005 Share Posted August 1, 2005 I'm trying to track a buzz that occurs at 3800-4000 rpm on my 04 RT. It sounds like it's coming from inside the right side fairing but I just can't isolate it. It sounds like it's plastic vibrating. Thanks Allan Link to comment
Ken H. Posted August 1, 2005 Share Posted August 1, 2005 It sounds like it's plastic vibrating.It's plastic vibrating. But seriously folks... Is it movement/wind induced, or engine vibration induces. I.e. - Can you get it to do it in the garage? Link to comment
travelinman Posted August 1, 2005 Author Share Posted August 1, 2005 Engine induced. Allan Link to comment
bmwkid Posted August 1, 2005 Share Posted August 1, 2005 For about 3 months I had a buzzing noise from my R1150R that happened only on decell at 3800 to 3500 rpm's. After a lot of trial and error I found the cause. Under the igntion switch there is a 6mm allen bolt that had backed out about 3mm,the wave washer on the bolt was bouncing around causing a loud buzz. Tighten the bolt noise gone---OH HAPPY DAYS Link to comment
BucksTherapy Posted August 2, 2005 Share Posted August 2, 2005 I have the exact same issue on my 02 RT. Can't find the source. Let us know if you find it and I'll do the same. Link to comment
Bruce Barrow Posted August 3, 2005 Share Posted August 3, 2005 My 99 R1100 RT had a right hand mirror that made buzzing sounds. Tightened up the retainer clips and all is quiet. Bruce Link to comment
snod Posted August 3, 2005 Share Posted August 3, 2005 The top right bolt on my front fender likes to come loose. Either that, or I don't like getting it tight enough. It has come loose creating a similar sound at least 3 different times. Some thing to check? Link to comment
JamesW Posted August 3, 2005 Share Posted August 3, 2005 Glad to see this thread as I thought I was the only one that had come to the conclusion that the racket I hear start up around 4500 RPM might be plastic parts rattling. Honest to god it sounds like a thrashing machine at times. I decided that it couldn't be anything serious after a few thousand miles else some kind of major failure would surely have occurred. I am determined to locate the source of this noise as it seems worse the longer I ride. Probly just seems like it as fatigue sets in after 8 or so hours in the saddle in hot weather. Link to comment
