knight88 Posted October 20, 2008 Share Posted October 20, 2008 Does anyone know which wire in the harness supplies the high beam for a headlight modulatorfor a 02 1150RT? The instructions are vague it says the wire could be at 3'oclock or 9'oclock and dosn't say what color. Link to comment
Crackenback Posted October 21, 2008 Share Posted October 21, 2008 Grey/Black = Fog lights. Brown = Ground White/Yellow = High beam White = Low beam On my 2002 RT I put the modulator on the fog lights, just to be different. Also If I don't want to run them for any reason I can turn them off by the dash switch. I spliced the wires on the headlight side of the wiring connector for the headlight and mounted the modulator to the top of the headlight assembly with double sided tape. Link to comment
knight88 Posted October 21, 2008 Author Share Posted October 21, 2008 Grey/Black = Fog lights. Brown = Ground White/Yellow = High beam White = Low beam On my 2002 RT I put the modulator on the fog lights, just to be different. Also If I don't want to run them for any reason I can turn them off by the dash switch. I spliced the wires on the headlight side of the wiring connector for the headlight and mounted the modulator to the top of the headlight assembly with double sided tape. Thanks! This was exactly what I was looking for Link to comment
