ScottFla Posted July 29, 2005 Share Posted July 29, 2005 Any recommendations or experience out there? What about mounting and powering options? Love to see pics of various member's bike and set-up. Thanks Link to comment
DavidEBSmith Posted July 29, 2005 Share Posted July 29, 2005 You need 6 volt power. Either the automobile power adapter plugged into a auto<->BMW adapter, or hardwired power. Tune to the proper station on the FM dial and viola. As far as mounting the XM radio, put it somewhere where it will stay dry and won't fall off. Link to comment
ScottFla Posted July 29, 2005 Author Share Posted July 29, 2005 thanks, so i presume i can't use the direct dc hook-up in to the power outlet. Link to comment
johnlt Posted July 29, 2005 Share Posted July 29, 2005 No, you need a 6V source. You can use the voltage converter in the XM plug or an aftermarket source. I would not recommend the FM modulator for signal because on a long road trip, you may need to change freqs frequently as you pass through towns that may have your selected frequency in use. Besides, the tape adapter is much higher fidelity and you can also use the radio volume/tone controls. The best interface is into an AUX port on the radio or direct into an Autocom or similar and use either the soft volume control on the XM or an in-line aftermarket volume control. Link to comment
TracerBullet Posted July 29, 2005 Share Posted July 29, 2005 I just tried the fm modulator from pa to mid Maine in my wifes car. It was a pain in the a**. As Johnlt stated any time you get near a bigger metro area all the frequencies are taken up an I had to constantly change the frequencies. It was so bad, fading in and out, that I decided rather than leave it in the wifes car I am just going to replace the stereo with a new head unit. sal Link to comment
kioolt Posted July 29, 2005 Share Posted July 29, 2005 I'm using the WIRED FM modulator on my bike. I've used it this way for over a year now and have never had any trouble when passing through a large city. The wired fm modulator disconnects the external FM antenna when the Roady is in use. It also has the 6 volt source for the Roady. Link to comment
ScottFla Posted July 29, 2005 Author Share Posted July 29, 2005 thanks, i've heard the antenna connection with FM transmission is great -- i use a FM transmission of I-Pod music to my car stereo and it works great -- with no antenna connection. I find the low end of the FM dial is best no matter where you go. once again, thanks for the data. PS -- does the r1200rt have an aux input? seems like it does. Link to comment
RCS Posted July 29, 2005 Share Posted July 29, 2005 "I just tried the fm modulator from pa to mid Maine in my wifes car. It was a pain in the a**. As Johnlt stated any time you get near a bigger metro area all the frequencies are taken up an I had to constantly change the frequencies" Out here in the Southwest it's not that much of a problem. I've traveled AZ, NV, NM, CO, UT, CA, OR, and except for the cities of LA and Phoenix, I never had to change my FM preset frequency to use my Roady. Regards Link to comment
kioolt Posted July 29, 2005 Share Posted July 29, 2005 I believe that the key here is whether you are using the wired or wirless fm modulator. The wired fm modulator inserts into the antenna lead. When using the Roady the wire fm modulator actually disconnects the antenna so you do not have a strong external signal coming in. I have never had any trouble using a wired fm modulator in about a year and a half and 38 thousand miles. Link to comment
CraCol Posted August 4, 2005 Share Posted August 4, 2005 The best interface is into an AUX port on the radio or direct into an Autocom or similar and use either the soft volume control on the XM or an in-line aftermarket volume control. JohnLT - Do you use the line out on the XM radio and connect that as another audio source to the intercom system? I'm using an XM2Go and a Baehr intercom on my R12RT.. Thanks, Craig Link to comment
ebuzzmiller Posted September 12, 2005 Share Posted September 12, 2005 You need 6 volt power. Either the automobile power adapter plugged into a auto<->BMW adapter, or hardwired power. Tune to the proper station on the FM dial and viola. As far as mounting the XM radio, put it somewhere where it will stay dry and won't fall off. [/quote sorry about the stupid newb question, but can you just use the BMW to Auto adapter to perform the change from 12 volt to 6 volt? any idea where to buy this cable? thanks Jim Link to comment
johnv1 Posted September 12, 2005 Share Posted September 12, 2005 Cycle Gadgets has a cable and converter for about $40 Link to comment
randy Posted September 12, 2005 Share Posted September 12, 2005 the cycle gadget unit is big. At least bigger than i wanted in my tank bag. I purchased a 2wheelinnovations.com unit, much smaller, and it has worked like charm. In addition I purchasd a 5 volt converter to run my Ique 3600 and it was very nicely built. So far I have really liked the size and quality of the 2wheelinnovations.com converters. Link to comment
